Will Turnip permit 15% ethanol year-round?
Personally I’d like to just see more proliferation of ethanol blends in general... I don’t wanna be forced into buying E15 if I don’t want to, but would love to have easy access to ethanol rich blends, maybe E30 and E47 in addition to E85...
I think that if one advanced timing and leaned mixture to take advantage of the higher octane of E30 and the cooling effect that alcohol has on combustion, you could about break even in mileage versus E10/87octane, with significantly greater power output |
I had to do a little research on this because it's been at the pump all summer here. The three months it has to be labeled for FFV only just like E85, never stopped me from putting either in any of my cars.
Petroleum rep on local radio yesterday said it doesn't really matter only 15% of Iowa's pumps are compatible and the state has a fund (tax payers) for pumps to be upgraded. If tax payers are going to pay(shouldn't) for an upgrade it should only be for Blender pumps. I also think all new cars should be FFV. It's just 1 sensor that $50 now if they choose to use it and software. If Brazil can do it the US should to. We should also drop the requirement to get all the water out of the ethanol to reduce the cost of producing it. |
Sorry, but I sure as heck don't want to pay $3.54 a gallon for water which pisses off the controls in the ECU.
Ethanol is garbage. The net benefit doesn't outweigh the net cost. People are throwing their lawnmowers away every year because the gas can't sit over winter without collecting water. The hoses dry and crack because they weren't made for alcohol. Car fuel economy plummets. It has 1/3 less energy as gasoline. It displaces food crops.
Sure, if this were Brazil I'd be all about ethanol, but this isn't Brazil, and we don't grow cane sugar. If burning ethanol were better, then law wouldn't have to mandate it. Instead we'd all just be burning it because it's better. Whenever a law compels an otherwise free market, you have to be very skeptical about what the real reason for the law was, because it sure doesn't have consumers best interest in mind. |
Study on Ethanol energy balance.
https://www.usda.gov/oce/reports/ene...ornEthanol.pdf "There is a low-input-energy segment of the industry that does better than the industry average. The energy balance ratio is 4.0 for areas like Iowa and Minnesota that use the lowest corn" That article doesn't address gasoline, but another one I found earlier said it took 1.23 btu of fossil fuels to get 1 btu of gasoline in the pump (0.81). I think the overall average for corn ethanol was 2.3 field to pump. https://www.extension.iastate.edu/ag...HofJuly07.html There's where the 1.23 number comes from. That article list corn ethanol at 1.36 but was done in 2007. Improvements have been made in the ethanol industry the top listed study is more recent. "Conclusion All the talk about ethanol being an inefficient energy converter is wrong. Moreover, the energy balance question is largely bogus. Whether you are concerned about weaning the U.S. from foreign oil, stopping global warming, or both, ethanol is better than gasoline and getting better every day." |
You've yet to address why the free market hasn't adopted ethanol for fueling our vehicles. Nothing is preventing auto manufacturers from producing vehicles that run on 100% ethanol, or gas stations from supplying it. In fact, even with ethanol subsidies, we don't have auto manufacturers building cars that run on high levels of ethanol. The government shouldn't be the first "solution" to a problem; it should be the very last. First, answer what problem a 15% ethanol mandate fixes. Next answer why the problem it fixes has to be addressed by the worst problem solver (government). |
I, for one, think you should either:
Change the title to something less politically brain-dead. |
Brain-dead. Clever.
How do you feel about year-round 15% ethanol? |
