Wind car
This is amazing. Man have we gone backwards. Check out the elegance of this car made in 1973. That is what needs to be reinvented for the X prize. :turtle::turtle:
That's amazing. Need to dig up more information...
How on earth do you get your vehicle to do faster then the power that is propelling it? I need to do more research on this, very nice post.
Sailing craft "create" their own wind when they start moving.
With proper sail design, trim & a low resistance hull (or chassis), the faster you go, the more apparent wind your sails "see". If you take advantage of the increasing apparent wind speed by trimming the sails (and/or adjusting your heading - because the apparent wind direction also changes), you can just keep creating more apparent wind and more acceleration (up to a point). An optimized sail, well trimmed, on an optimized low resistance hull (hydrofoil, in this case) can do amazing things... like this: [youtube]http://www.youtube.com/v/oxUtTaOknpc[/youtube] |
The sailboat speed record is 56mph was set is 2005. The iceboat speed record is 143mph set in 1947. The land yacht speed record is 116mpg set in 1999.
Needless to say, I'm into sailing. I can't count how many times I've thought it would be great, silly fun to mount a sail on the Blackfly and see what happens. :D
It's all about the angle. You can achieve the highest speeds when the wind is actually coming from right angles to your desired direction of travel. You start out with your sail angled a little bit, acting like a wing sticking straight up. The wind lifts your sail/wing forward. As you gain speed, you trim the sail to keep its angle of attack from becoming neutral to the new "perceived" wind that the sail sees.
I saw this funky car in a 1980's Popular Science. It was on the cover. |
Does this same technology apply to vehicles with no ambient wind?
EG - car moves forward, 'sails' get wind, car moves faster forward. but if the car holds still it sees there is actually no wind when it is not moving. |
Short answer: you need "true" (ambient) wind for this to work.
the book New Electric Vehicle, has a chaptor on an air foil car that is simaler, it has a horse shoe shaped wing. |
