EcoModder.com
-   Alternative Transportation (https://ecomodder.com/forum/alternative-transportation.html)
-   -   Wind resistance while cycling. (https://ecomodder.com/forum/showthread.php/wind-resistance-while-cycling-2475.html)
Peakster 05-21-2008 03:50 PM
It's a pretty windy day today which will be great biking to work with the tailwind, but real sucky when I travel home.
There are 2 ways I can get home though: one with a direct-head on wind and one with a more of a cross-wind. I'm wondering, is it less efficient to travel in a cross wind (because more surface area is being hit by the wind :confused:) or one that's head on?
MetroMPG 05-21-2008 04:06 PM
Headwind! Just a guess based on the frontal area issue, plus the fact that you'll be steering into the crosswind and adding tire scrub, increasing RR.
In the right crosswind, I pretend that I can "sail" myself forward by twisting my upper body to generate forward lift. :P
Peakster 05-21-2008 04:10 PM
Originally Posted by MetroMPG (Post 27527)
In the right crosswind, I pretend that I can "sail" myself forward by twisting my upper body to generate forward lift. :p
Ha ha! Somehow that doesn't surprise me coming from you MetroMPG.
Okay, headwind it is! Thanks. Still, if someone knows the absolute answer or can link me to a site, please chime in :).
JohnnyGrey 05-21-2008 04:14 PM
Crosswind. You don't steer against it, you just lean against it a tiny bit. Much easier than riding into it. Simple vector math problem, draw it out. :)
Peakster 05-21-2008 04:18 PM
I was never good at math. Hmm, we got some conflicting advice! :eek: who do I believe now? Are you 100% sure JohnnyGrey?
Figjam74 05-21-2008 04:22 PM
Head on is worse, no doubt in my mind.
Peakster 05-21-2008 04:23 PM
Okay, thank you :)
MetroMPG 05-21-2008 04:26 PM
Go with the majority, Peakster!
I think Johnny is closer to the right answer, because his effectively is "it depends" (TM) - on the strength & direction/vector of the wind.
JohnnyGrey 05-21-2008 04:47 PM
Yep, I'll stay with my original assessment.
SVOboy 05-21-2008 05:38 PM
Go where the workout is.
