Wind turbine on the front of a car.
Tell me all the reasons why putting a wind turbine on the front of a car is a stupid idea.
And no I don't want to do it. I think its a stupid idea. I think this idea ranks up there with putting an alternator in an electric vehicle to charge the batteries as you drive. :rolleyes: |
Smokey Yunick did it on a race car but that was only because it had a problem throwing belts.
It seems to me that such a set-up would increase aero drag thus cancelling or more than cancelling out any gains. I had that "brilliant" idea as a kid but my engineer uncle explained why it probably wouldn't work. For sure it would fail bolted on the roof, for example. Someone recently suggested putting one in the engine compartment, an already draggy place with lots of airflow(?). I think it would either still increase aero drag but maybe not enough to notice. And/or it might not spin enough, enough of the time to keep the battery charged. Maybe the answer isn't simple? :confused: |
Not actually that dumb of an idea. It actually works if you happen to have a nice, windy dry lake to play on: https://en.wikipedia.org/wiki/Blackbird_(land_yacht)
But for an ordinary vehicle, I think the biggest drawbacks are 1) carrying around all that excess weight when the wind's not blowing; and 2) chopping up other vehicles, pedestrians, and so on with the propellor :-) |
A sail would look better.
FYI:
Ram air turbine https://en.wikipedia.org/wiki/Ram_air_turbine Quote:
From the same link: https://upload.wikimedia.org/wikiped..._%28Can%29.jpg Quote:
http://forums.pelicanparts.com/uploa...1446497270.jpg Airbus A380 http://a380flightdeck.tumblr.com/pos...am-air-turbine http://forums.pelicanparts.com/uploa...1446497289.jpg http://forums.pelicanparts.com/uploa...1446497311.jpg Quote:
However, maybe if you are far from the main power source as with a train car or a caboose, and have a power requirement while underway, then it might make sense. Then again, train cars have wheels and axles, which could be mechanically/parasitically drawn upon for generator power, right? |
I don't think it's a stupid idea. Expecting it to work anywhere but parked facing into a headwind is stupid.
Lots of ways to recover energy normally lost in braking. The best is to not brake in the first place.
regards mech |
Underway, or not underway, this 4x4 RV has roof mounted solar panels.
EarthCruiser FAQS- Questions we want you to ask….. | Earth Cruiser http://earthcruiser.com/wp-content/u...d-Oregon-7.jpg The RAT will give way to solar panels in most automotive use applications I suspect. |
Around 2000, Popular Science / Mechanics had a small write up on an electric van with a fan on the roof. ( It was mounted horizontally. )
The blades were designed in such a way that they would fold flat as they turned, thereby reducing drag. They claimed that even in a parking garage, the wind would turn the blades. So agreed - not such a stupid idea after all. I wonder what became of the prototype though. |
wind turbine
*The mechanical efficiency of the generator might be 98%. *Combined,for every 746-Watts of power extracted,you'd have to overcome 964-Watts of drag for the turbine alone,then add in the drag of the nacelle,supporting strut,interference drag at the attachment interface,plus you'd be driving in the turbulent wake of the turbine; of which it's kinetic energy could never be converted back to useful pressure,disturbing local body airflow,increasing the car's overall aerodynamic drag. *Think of a side-view mirror the size of the rotating disc of the turbine! *It could be the poster child for Entropy.:p |
