EcoModder.com
-   -   Winter Diesel (https://ecomodder.com/forum/showthread.php/winter-diesel-21463.html)
Hauki 04-16-2012 05:48 AM
Winter Diesel
How bad does this affect FE?
I am not quite hitting the manufacturers claimed FE I should be in my van, and I am doing everything right. So maybe it is the winter diesel affecting it? Can any of you diesel owners in cold climates shed any light?
In previous vehicles (Petroleum fueled) I have always got great FE, much better than manufacturer claims, but I am struggling with this diesel.
AndrzejM 04-16-2012 05:55 AM
Winter diesel is a bit thinner that summer one so it probably have slightly less BTU. But it shouldn't affect FE so much. Maybe there's something wrong with your engine or car? Check brakes, tyres pressure, air filter etc.
jtbo 04-16-2012 07:02 AM
It does affect some, BTU 129 500 vs 110 075 Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com, in practice I have no hope to go under 5l/100km with winter stuff but with summer stuff I can manage to 4.8l/100km if weather is nice. This even at winter air is cooler so more oxygen to cylinders. Same tires and pretty much same everything else, however two winters ago it was that I noticed that. Last winter was real disaster in fuel economy wise for me.
drmiller100 04-16-2012 11:10 AM
It depends on the climate. If temperatures go much below zero C then they often mix number one diesel in with the regular diesel.
If temps do not go below zero very much, then the formula does not change.
I lived in an area where -20 C was pretty common. In winter I expected 20 percent worse mileage.
I found the white bottle PowerService helped restore that mileage somewhat and also made for easier starting.
Hauki 04-16-2012 11:22 AM
Thanks guys, so soon when it changes to summer diesel I hope to see improvements. If it affects it 20% I will be really happy. But any improvement even a 2% would be welcome.
drmiller100 yep it is proper winter diesel, this year it only got to -22°C but last year it was -33°C so I imagine the diesel has many anti-gel additives taking up valuable space.
jtbo 04-16-2012 12:48 PM
Here it has been summer diesel at least 2 weeks, maybe even longer.
I would think that you have had summer quality longer at the coast.
It was enough cold this winter here, -36C or so, but then again I live at one of the coldest place if lapland is excluded.
Hauki 04-16-2012 01:17 PM
You are right for most places, but on our island, population 850, there is only one diesel pump so if the huge tank was filled with winter diesel it will remain there until it is used up.
jtbo 04-16-2012 01:26 PM
Ah, it used to be like that at here too, population of 1000, but so few used that pump that petrol station owner could not realize cash to fill up tanks every time they went dry, which meant that they had to stop selling the stuff, it has been now around two years that they have been trying to sell that station, but there is not lot of hope to find anyone that would take such high risk.
That means that I have to drive 60km to just get tank filled up.
