EcoModder.com
-   -   winter tire psi (https://ecomodder.com/forum/showthread.php/winter-tire-psi-19797.html)
echo-francis 12-16-2011 09:03 AM
winter tire psi
i change my tire today and the max psi is 35 my summer tire was 45 can y put 45 in my winter tire ?
Daox 12-16-2011 09:27 AM
I've run 35 psi max snow tires at 50 psi before. I forget what my current winter tires are rated at for max psi but they'll have 50 in them too.
bandit86 12-16-2011 10:08 AM
I wouldn't go past max but keep an eye on them. If temperature goes up so will tire pressure
KrZ 12-16-2011 03:16 PM
I put 42psi in my 35psi summer tires without problems, but I would stick to the speed limit.
Diesel_Dave 12-16-2011 03:35 PM
Look on the tires to see what the max pressure rating is. It depends on the specific tire. Winter/summer doesn't really matter.
ajjct 12-16-2011 05:29 PM
i have firestone winterforce tires that max psi is 50
CigaR007 12-16-2011 05:30 PM
I keep my winter tires inflated at 35 psi. I want them to maintain their flexibility at cold temperatures (lower than -10c). Over-inflation of winter rubber is not something I would personally endorse. I want all the grip available on icy/snowy surfaces.
Just my 2 cents.
brucepick 12-17-2011 08:56 AM
Just my 2 cents.
I'm going to try look at this in some detail - after a couple quick introductory notes.
First I have to say that I run my tires at high pressure. Let's just say that I start with the sidewall imprint. I do that for my summer and winter tires (Michelin X-Ice 2, rated 51 psi max).
Here's my personal favorite article on tire pressure. Says nothing about snow but it does say plenty about the benefits of increased tire pressure, including in rain: Driving Under Pressure (full article) - CleanMPG Forums
Regarding flexibility
If the tire is extremely cold, the rubber loses flexibility. Reducing air pressure does not soften up frozen rubber. You feel the flat spot as it rolls. I believe that's below about 0 deg. F. (-18 C.) Living in southern New England USA, I experienced it one time at about -5 F or -20 C (before I bought the X-Ice 2's). After 30 minutes drive the frozen tires warmed up and felt normal.
Now if the tire has low air pressure, it wants to flex (bend) when it hits a bump. But if the tire is brittle from cold, it cannot flex, so possibly could be damaged. If the tire has more air pressure, it will hold its shape. So may be less likely to be damaged by "bending" when frozen stiff, if it has more air pressure.
Higher pressure creates a smaller "flat spot" on the road. The car's weight is resting on that flat spot. Car's weight does not change while driving, aside from loading of occupants and cargo. So the same weight resting on a smaller contact flat spot gives higher pressure per square inch (or per square cm). That higher pressure gives better traction. And that is why autocross drivers run their cars at higher tire pressures. Google search on "autocross tire pressure"
wdb 12-17-2011 09:21 AM
Winter tires are formulated for cold weather, including being made with a different rubber compound.
I see a significant drop in traction - in dry conditions, as well as wet or snow conditions - when I hyperinflate winter tires. The effect is much more dramatic than what I've seen with summer tires. So, while I still run pressures considerably above manufacturer recommendations, I do tend to run lower inflation pressures in the winter than I do in the summer.
Ryland 12-17-2011 09:41 AM
Both sets of my snow tires are also rated for 51psi so I keep them at 50psi.
From the studies I've read about tire pressure, higher pressure gives better traction on snow, ice and wet pavement, my owners manual also suggests bumping the tire pressure up for any highway driving and I have nearly 30,000 miles on my snow tires, so they are nearly wore down to the wear bars and the treat wear is dead even, no bald ridge down the center like people fear with bias ply tires that were popular from the 1800's to 1970's.
CigaR007 12-17-2011 03:24 PM
Autocross drivers, if my memory serves me well, bump their tire pressure considerably in order to reduce sidewall flexing, thus improving traction and steering response, especially while cornering. That's a given, except that the surface on which they drive is free of snow and ice, which changes the game, traction-wise.
I have no problem bumping my tires to 40 psi in the Summer, but Winter is a totally different scenario that requires, in my opinion, a certain caution regarding tire inflation.
Overinflation diminishes the ability of the tire to respond to road irregularities, such as snow and ice debris, which in turn will reduce the overall contact of the tire to the road. Now, it is obvious that road conditions, in Winter, can vary greatly in a short span of time. I prefer to adopt a less aggressive Winter tire inflation as a way to get the best grip as possible no matter what the road conditions will be.
Any other time of the year I would agree with you, but during Winter is a different story.
