worn out civic hx
so i started to try to employ some of the driving techniques from the sight in my worn out 98 civic hx with over 300k on it and super low compression befor i put in my new build im doing and i have seen a good return. i went from a avg of 29mps to 36 avg!
How were you driving before?
like a kid lol
your new build will be replacing the stock engine? or something else?
replacing the stock engine. the compression numbers are way under oem honda speck. i had around 120psi on each cylinder and min is 135psi.i came buy a good d16y5 head at pull a part and got it for a good price.so i decided to build something with economy in mind. and this is what i came up with. im still on the fence about the transmission but may go with a honda vx or even the stock hx trans. im shooting for avg 40mpg with mixed driving and would like to see the old epa numbers of 38 city 45 hwy. i have read that the vx trans will net 1800rpm at 60 mph and net around 60 mpg hwy. ?
im going back to a factory exhaust also this weekend if i have time. the exhaust thats on the car is not what it needs. rightnow it has a 4-1 header with a cat and 2.25 with a 09 civic muffler. it sounds good but has taken away alot of low end torque!
I wouldn't go replacing the head without making sure it's the valves and not the Rings that's the problem. If it's just worn valves, I would recommend a good valve job. It will probably cost more but you will have a basically brand new head and not one with miles already on it.
im not just replacing the head sorry if that what i made you think. i rebuilt the engine top to down. :thumbup:
http://i749.photobucket.com/albums/x...pszf9eeehr.jpg |
How long has the clear cam pulley and timing belt cover been on the car? Looks new. I am curious about clouding over time.
