Would a modern car with drum brakes all-around still have a chance?
I'm sure most people have already been totally convinced that disc brakes may be inherently "superior", even though economy cars and some trucks still resort to drum brakes at the rear-end. But it's worth consider how drum brakes retain a foothold on the heavy-duty truck market, even though it's most noticeable on models meant to feature off-road capability.
https://1.bp.blogspot.com/-R4zc0yl1S...madeireiro.jpg Among the reasons why I still see a lot of trucks with drum brakes all-around is they're often pointed out to be less prone to have its friction surfaces in contact with contaminants, which is a common issue on most rural environments. Then it turns out to question the suitability of all-around drum brakes for an economy car, considering not only the manufacturing cost which is still usually lower for a drum brake but also that not every farmer in countries such as mine may afford a medium-duty 4WD truck for instance. |
Well the truck brakes are massive, almost filling the offset area of a 20" rim and sticking out from the rim.. You also downshift for hill descent which cars typically don't do as well as being more aware of traffic and driving slower. OTOH, my daughter is complaining to KIA about her rear discs making noise after driving on a dirt road.
I would think that truck discs would be bigger and heavier than the equivalent drum brake |
Maybe cheap electric cars will bring back four wheel drums.
, there are “supposedly” other benefits as well but maintenance sucks, so there is that. |
However, plenty of reviews of the car dinged it for having "cheap" drum brakes without looking into the engineering reasons why. |
Recently I had a talk with a friend who worked for a while at the Brazilian branch of Scania, and he is still more favorable to drum brakes on heavy-duty trucks.
The only down side to drum brakes that I know of is dumping the friction heat on twisty roads or long downhills. I know of big rigs water spray cooling on the drums, but that is frowned upon.
