Old 11-01-2009, 08:44 PM   #1 (permalink)
for(cD i=.25;i>.16;i--)
UltraHatchy - '00 Honda Insight 5spd
90 day: 63.55 mpg (US)
Are HID conversion kits worth anything?
www and eBay are full of drop-in or plug-and-play HID conversion kits that offer 3x more light and 35w draw (v 55/60w draw) as compared to halogen bulbs. There is a legality issue, as well as a 'they might melt stuff' issue. Are there any other issues that might prevent an intrepid ecomodder from going ahead with a conversion to HID and reaping the (admittedly minimal) efficiency benefits of these lights while enjoying more light output? Has anyone gone ahead and done the switch?
Old 11-01-2009, 09:12 PM   #2 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 28.73 mpg (US)
I have heard a lot of bad things about them... Like the Melting Stuff issue, and Waiting for them to warm up and sometimes they flicker or turn off going down the road (or so iv heard)
In other words I would do some good research on them before Id spend the hard earned money on them, I chose not to get them when I was getting new bulbs... I got the SilverStar Ultras that are 4100k color temperature, they are decently bright, ALMOST worth the $54 I paid for them...
Old 11-01-2009, 09:19 PM   #3 (permalink)
The Sylvania EcoBrights are advertised on this site (pops up occasionally). Any word on them? They're pretty hard to find. Also, these HID kits seem to start at $10 or $20. 2 bulbs, 2 ballasts, wires, and 10 zip ties (wow).
Old 11-01-2009, 09:41 PM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Most of the cheap HID arcs aren't aligned with the same orientation as OEM bulb filaments, therefore don't focus properly in standard reflector housings, and cause vicious light scatter that dangerously blinds oncoming traffic.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 11-02-2009, 12:12 AM   #5 (permalink)
Deceptive - '98 Dodge Neon R/T
90 day: 44.38 mpg (US)
if your going to do hids, get a philips kit, there hard to find and expensive, but there worth it.
i got an ebay kit for my wifes car before i knew better, it works ok, except it flickers now after 2 years, and most cheap ones eliminate your highs. Which is funny because her kit eliminates her highs, and now, after 2 years of not having highs, suddenly she has highs.
Old 11-02-2009, 12:33 AM   #6 (permalink)
my first gmc's Avatar
Sierra - '96 GMC Sierra
90 day: 20.89 mpg (US)
White Lightning - '10 Mitsubishi Lancer GTS
90 day: 27.18 mpg (US)
Did someone say philips kits?
Home
Old 11-02-2009, 12:43 PM   #7 (permalink)
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
Don't buy the plug-and-plag kits, they put LESS light onto the road, and MORE light into the eyes on oncoming cars. The reflector housings your halogen bulbs use are not designed for the light output nor pattern that HIDs produce.
The only way to do it correctly, is to retrofit a HID projector from a car that comes stock with HIDs into your stock light housings... not an easy task.
And as for them 'melting stuff', that is ridiculous. They put out LESS heat that halogens (35w vs 65w). The only thing you could melt would be wiring, and you would have to be pretty dumb to do that, because that means you are running them without a relay.
Old 11-02-2009, 09:15 PM   #8 (permalink)
Driving the TurboWeasel
The horsepower difference is minuscule. It's not worth the hassle. If you want better lights, get better bulbs (NOT Sylvania SilverStars, they are over-priced garbage that rely on optical tricks to make you think you're getting more light).
The ultimate for better light legally is a relay harness.
2012 Chevrolet Cruze Eco 6MT
Old 11-02-2009, 09:33 PM   #9 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Jeep Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Dodge Neon SE
90 day: 33.46 mpg (US)
S'Crew - '02 Ford F150 Supercrew XLT
90 day: 16.4 mpg (US)
Ranger - '90 Ford Ranger
Last 3: 28.02 mpg (US)
Not the Jeep - '03 Dodge Neon SE
90 day: 34.11 mpg (US)
I'm going to switch my projectors to HIDs in the next month or two. I'm planning to use a relay harness to keep the HIDs on for low when the 70w highs come on.
Yes, thats a set of aftermarket lights on my Neon... Nice look...
When it comes to Heroes, RENEGADES are mine!
Old 11-02-2009, 09:37 PM   #10 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Good grief! You think you'll get a noticeable improvement in MPG from 40 watts?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Propane or natural-gas conversion kits! blackjackel Fossil Fuel Free 24 10-18-2012 09:40 PM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 57 10-24-2011 11:25 PM
FS Silver TDI Corrado with Black Leather 100% Diesel Conversion with Origninal Paint G60ING For Sale 8 03-09-2009 12:34 AM
E-Bike Conversion Kits in Canada caledondave Introductions 3 07-30-2008 10:11 PM
