EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Xgauge: timing advance: IGN / RPM (https://ecomodder.com/forum/showthread.php/xgauge-timing-advance-ign-rpm-27273.html)
topcat 10-15-2013 01:03 PM
I know that the scangauge of timing advance (IGN) can help find a good efficient place to run. The higher the advance, the better. But I also find it increases with speed (& RPM). To remove the dependency on speed, we could do IGN/RPM as an Xgauge. Can anyone clever work out how to do it?! Preferably for the ISO comms protocol. Thanks!
topcat 10-19-2013 04:39 PM
To answer my own question, from what I read, it seems that the xgauge will only allow you to use one variable per xgauge. You can tweak that variable with a gain and offset, but you can't take two variables and do X/Y.
E.g. it works like y=mx+c where m is gain, c is offset, x is input variable, y is output of xgauge.
Maybe someone might know a clever trick to get around that?
gone-ot 10-19-2013 05:31 PM
Sounds like a task for one of the aftermarket "add-on" OBD reader programs that use a laptop computer to both collect & analyze data.
