To answer my own question, from what I read, it seems that the xgauge will only allow you to use one variable per xgauge. You can tweak that variable with a gain and offset, but you can't take two variables and do X/Y.
E.g. it works like y=mx+c where m is gain, c is offset, x is input variable, y is output of xgauge.
Maybe someone might know a clever trick to get around that?
