Three Dirt Cheap DIY Electric Cars – Part 5
by Benjamin Jones on December 12, 2008
In this series…
Part 1: So you want a cheap 100% electric car…
Part 2: Ben Nelson’s $1200, 1995 Geo Metro “Electro-Metro”
Part 3: Darin Cosgrove’s / Ivan Limburg’s $955, 1992 Geo Metro “Project ForkenSwift”
Part 4: Paul Holmes’ $2200, 1971 VW Beetle
Part 5: Parting thoughts
Parting thoughts…
Naysayers are quick to scoff at medium-speed electric vehicles as “useless”, arguing that they’re too slow and don’t go far enough on a charge (OK, they say that part about almost all EV’s).  What these people fail to understand is that their vehicle needs are not the same as everyone else’s vehicle needs.
Tens of thousands of people in North America and elsewhere have already bought and are using low- and medium-speed electric vehicles for local driving, from actual golf carts, to NEV’s (neighbourhood electric vehicles), to faster cars such as the classic Citicar/Commutacar, to the newer Zap Xebra.
And now they’re building their own, on the cheap!
Feel motivated?  Well then, here’s what we learned about budget EVs from the 3 amigos, both in general and specifically:
In general…
Be realistic
Understand that you probably can’t build a highway capable EV with a 40+ mile range on the cheap.  (But if you’ve done it, drop us a line!)  Each of these cars tops out around 45 mph, and a more realistic “working” top speed is probably low to mid 30’s.  Steep hills are to be avoided.
No experience required
– two of the builders had zero experience with electric vehicles
– one had little experience working on cars in general
– all you need to know you can learn on the Web
Reuse & recycle
Read the build threads for these vehicles and you’ll discover lots of creative low-cost recycling ideas.  “Repurposed” parts in the ForkenSwift, for example, include bits from a dead inkjet printer, old tricycle, dead 12v cooler, old bed frame, used welding cable and more.
Patience is a virtue
The challenge of buying used parts and scouring eBay for killer deals is that it will probably take some time to find the things you’ll need.  If you’re an impulsive type prone to temper tantrums when you can’t get something you want RIGHT NOW, a budget EV project is probably not for you.
Let no parts go to waste
Just because you’ve decided the internal combustion engine is useless for your purposes, doesn’t mean it’s actually worthless.  In the case of both Metro projects, slightly more money was recovered by selling good parts (fuel tanks, radiators, working engines) than the cars originally cost!  As well, hundreds of dollars were recovered by selling the forklift chassis after stripping the electric parts.
More specifically
Go light
By definition, a medium speed budget EV is not going to need to carry a lot of batteries or generate a lot of power.  Which means you should try to find a lightweight host car to keep the overall power to weight ratio manageable.
Forklifts and golf carts and used parts, oh my
The biggest fleets of EV’s in the world are found in warehouses and on golf courses.  The companies that sell/service/repair these vehicles are potentially a good source of affordable used parts, particularly if you take an entire old unit off their hands.
The 72 volt threshold
The lower your system voltage, the lower your component and battery costs.  That said, a 48 volt 400 amp subcompact car is just barely workable in what most people would consider normal driving, and only on flat roads.  A 72 volt setup is more realistic, and as it turns out, motor controllers that can handle 72 volts seem to be just below a threshold where the price goes up significantly.
A 48-72 volt battery pack (assuming lead-acid) also keeps you closer to the weight limit that a smaller host vehicle can carry without exceeding its gross vehicle weight limit (affecting suspension & braking ability).
Used batteries
Second hand batteries can be a viable option, which is good because along with the motor and motor controller, the battery pack is one of the 3 costliest parts of an electric conversion.  Depending on your range needs, it is possible to find used ones that may meet your minimum range goals.  Two of the three cheap EV’s featured in this series are running on batteries from other EV’s owners which were either upgraded, or replaced once they no longer met their minimum range needs.
Connect with experts & people with experience
Electric Vehicle Discussion List – evdl.org
EValbum – evalbum.com
EcoModder Fossil Fuel Free forum – ecomodder.com/forum/fossil-fuel-free.html
DIY Electric Car forum – diyelectriccar.com
Well – what are you waiting for?
Popularity: 9% [?]
{ 3 comments }
1 Arcie Bell April 12, 2009 at 5:13 am
Hi, just a bmall note to say a BIG thank you for the encouragement all Ecomodder comments give me, a 66 year old with hopefully a good few recycling miles left in me. Doing Irelands Cancer Care conversion–start date 1st April 2009 –with mechanical knowledge but new–i mean NEW–to Fork Lift welectrics I,m converting a Toyota Corolla using re-cycled parts –primarily v36volt and 48volt parts. with a whole bundle of local help to complete the EVcar. (yet to be named via a School competition.
I,m really indebted to YOU at Ecomodder AND all those brave souls who went and are currently going before me ! Regards Archie Bell
2 terry May 8, 2009 at 1:38 pm
do you know anyone who is building these cars as a buisness
3 John October 3, 2009 at 1:53 pm
I would like to obtain the drawing with dimensions of the adapter plate and other machined parts for the Geo Metro conversion using the 72 volt motor. Also interested in getting some additional specs for machined components learned by experience and trail and error. Thanks, John, CT, USA 203 671 2677
Comments on this entry are closed.
