Old 06-11-2010, 01:37 PM   #1 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Honda Insight Tail Extension Project
Honda Insight Tail Extension Summary Page
Quick-Links To Various Aspects of Project
Mounting System Framework 1
http://ecomodder.com/forum/showthrea...tml#post179658
Mounting System Framework 2
http://ecomodder.com/forum/showthrea...tml#post181187
First Piece of Foam in Place
http://ecomodder.com/forum/showthrea...tml#post184379
Rough CAD model of Extension
http://ecomodder.com/forum/showthrea...tml#post185387
Absolutely Beautiful Aptera Photograph
http://ecomodder.com/forum/showthrea...tml#post186578
Making Use of the AeroHead Streamlining Template 1
http://ecomodder.com/forum/showthrea...tml#post186492
Making Use of the AeroHead Streamlining Template 2
http://ecomodder.com/forum/showthrea...tml#post187635
Making Use of the AeroHead Streamlining Template 3
http://ecomodder.com/forum/showthrea...tml#post189335
Extension Removed From Car for First Time
http://ecomodder.com/forum/showthrea...tml#post187646
Rear Hatch Hardware
http://ecomodder.com/forum/showthrea...tml#post190135
Verifying Top Angle of Extension
More Info on Hatch Mounting System
http://ecomodder.com/forum/showthrea...tml#post190160
Adjusting Top Angle of Extension
http://ecomodder.com/forum/showthrea...tml#post190180
Beautiful Rendering of Tail Extension by Botsapper
http://ecomodder.com/forum/showthrea...tml#post190269
http://ecomodder.com/forum/showthrea...tml#post194208
http://ecomodder.com/forum/showthrea...tml#post194359
http://ecomodder.com/forum/showthrea...tml#post199524
Question About Vortex Generators Under Tail
http://ecomodder.com/forum/showthrea...tml#post191244
More on Rear Hatch Construction
http://ecomodder.com/forum/showthrea...tml#post193834
Design Concepts for the VW 1L
http://ecomodder.com/forum/showthrea...tml#post194558
SiverInsight2's Spy Photo
http://ecomodder.com/forum/showthrea...tml#post198744
Final Stages of Build for 2010
http://ecomodder.com/forum/showthrea...tml#post198995
Side Marker Details
Rear Hatch Clearance
http://ecomodder.com/forum/showthrea...tml#post199004
Wiring Loom Inside Extension
http://ecomodder.com/forum/showthrea...tml#post199007
First Impressions After Driving With Extension
http://ecomodder.com/forum/showthrea...tml#post199129
Pictures of Extension
http://ecomodder.com/forum/showthrea...tml#post199474
http://ecomodder.com/forum/showthrea...tml#post202974
MetroMPG's Ingenious WebCam
http://ecomodder.com/forum/showthrea...tml#post200415
First Severe Weather Test on Extension
http://ecomodder.com/forum/showthrea...tml#post200940
Summary Table for Build
http://ecomodder.com/forum/showthrea...tml#post201926
Limited Run Gas Mileage Test
http://ecomodder.com/forum/showthrea...tml#post203744
http://ecomodder.com/forum/showthrea...tml#post203904
Center of Pressure from Side Winds
http://ecomodder.com/forum/showthrea...tml#post209106
You can see the full array of pictures at:
Picasa Web Albums - Jim - Honda Insight...
__________________________________________________
Honda Insight Under-Body Smoothing Panel Project
http://ecomodder.com/forum/showthrea...lly-10638.html
Jim.
See also: MetroMPG's Insight boat tail project ...
MetroMPG's boat tail thread details:
  • design / construction
  • tuft testing (video)
  • A-B-A testing, showing 9.7% better mileage at 80 km/h (50 mph)
  • 110+ mpg (US) sustained at 80 km/h (50 mph) on a level road, warm weather
  • best ever trip mileage on a frequently driven route
ID:	7587   Click image for larger version
Last edited by 3-Wheeler; 01-05-2011 at 01:46 PM.. Reason: Create Summary Page for Build
The Following 27 Users Say Thank You to 3-Wheeler For This Useful Post:
2003protege (01-19-2012), Bicycle Bob (08-08-2012), California98Civic (06-26-2021), Cd (11-27-2011), christofoo (04-30-2013), darrylrobida (10-07-2012), ECONORAM (01-10-2013), eMax (04-24-2014), freebeard (07-11-2017), HHOTDI (01-14-2013), HyperMileQC (08-15-2012), IamIan (02-08-2011), j12piprius (12-11-2014), JasonG (05-06-2011), jime57 (07-11-2011), menaus2 (01-11-2011), MetroMPG (01-07-2011), Mira (04-27-2013), NachtRitter (04-02-2013), NeilBlanchard (02-03-2011), Pawtuckett (07-25-2012), Piwoslaw (07-12-2011), RedDevil (08-07-2014), redyaris (07-09-2011), Regenerit (08-12-2012), SoobieOut (12-23-2010), tumnasgt (01-29-2011)
