Old 08-15-2010, 11:09 AM   #71 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by silverinsight2 View Post
....Will the interior of the tailcone be available for light storage?....
I suppose, but the small hatch leading to the large internal space, will make it 'interesting' to get bulky items in there!!
It would have been nice to store let's say a bicycle back there, but I did not want to create an even larger opening to get the bike in that area. It's just the way the project is working out due to the required mounting system to the car body.
Jim.
Old 08-16-2010, 04:05 PM   #72 (permalink)
Hello everybody!
Wow,great job..
Old 08-16-2010, 11:00 PM   #73 (permalink)
discovery's Avatar
Yes this is a nice job with a lot of work and love, keep it up
P.S. can't wait to see more of it.
navivovas- ot kude si be brat?
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 08-17-2010, 05:42 AM   #74 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Nice work - can't wait to hear the results and the mpg gain
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 08-17-2010, 12:59 PM   #75 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Fantastic job so far!
The earlier comment about hammering out aluminum panels into any shape reminded me of the early days of Porsche auto building. Where Dr. Porsche only had one man who was good enough to hammer out his panels. Problem was his only body craftsman was too drunk to work most days, which greatly limited his car production.
Old 08-17-2010, 02:36 PM   #76 (permalink)
3-Wheeler's Avatar
Aerohead Streamlining Template
This post is an attempt to clear up what shape the Aerohead Streamlining Template is.
This picture shows just one circle superimposed over the Template.
The next picture shows that there is, to best of my knowledge, only one circle and a tangent line that make up the shape of the Template.
This last picture shows that the template appears to be straight in this section, and that this straight area begins around the 65% mark on the Template length.
The main reason that I think the Template is straight in this area, is that it has to be, and for several reasons:
1) Aerohead has stated on several occasions that the 'tail' of the Template can not exceed an angle of 22° to avoid flow separation.
2) Well, at the 65% length of the Template, the angle is already at this point. Therefore the remainder has to maintain this angle to adhere to the 22° rule. This dictates replication by forming a straight line to the tail end at the 100% point.
The curvature of the Template up to the 65% point, at least as close as the pictorial can be rendered on my CAD program, shows that a single curvature provides a very close replication of the Template curve.
If this is really the case, and everyone thinks this is reasonable, then a math model of these shapes can be developed for future use by others on the forum.
Jim.
ID:	6600   Click image for larger version
ID:	6601   Click image for larger version
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post:
davidgrey50 (08-17-2010), ECONORAM (03-11-2011)
Old 08-17-2010, 07:46 PM   #77 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
How much better does a circle fit, versus the parabolic fit you discussed here?
Old 08-18-2010, 07:35 AM   #78 (permalink)
Botevgrad,Bulgaria.
Old 08-19-2010, 11:41 AM   #79 (permalink)
3-Wheeler's Avatar
Hi Robert,
Fortunately, that old file and spreadsheet data were saved by yours truly, such that further numbers could be calculated and shown here:
The previous post had this chart of information that was gleaned from an earlier analysis of the Template. The points shown in the table were 'picked' from the Template via a graphics editing program, thrown into the spreadsheet and analyzed numerically to allow a curve-fit to be developed.
A further column of data shown in yellow is the change in angular curvature for each picked point from the Template.
The change in curvature is not consistent in it's change from point to point, indicating that these picked points are not close to ideal. Therefore another approach to interpreting the Template is in order.
This picture is a collage of three smaller pictures, and shows how closely the a single radius matches the Template in the area from 0% to 60% cordal length.
The match is pretty good, and at least my eye can not determine if multiple radii would provide a better fit in this area.
The section from 65% to 100% cordal length seems pretty clearly identified as angled at the maximum allowable of 22°, so this portion is not under consideration, unless others have different theories on the intent of the Template shape.
To sum up, this is my best guess based on the given shape of the rendered Template.
Jim
ID:	6611   Click image for larger version
The Following User Says Thank You to 3-Wheeler For This Useful Post:
RobertSmalls (08-19-2010)
Old 08-20-2010, 06:35 PM   #80 (permalink)
template
Jim,the template's aft portion is basically modeled on the aft portion of a L/D= 2.5 streamline body of revolution as displayed in one of Hucho's tables.It should be mentioned in the abstract for the 'Template' thread.
I would have done a photo-enlargement of a small image and attempted to 'clean it up' with a French curve,and in so doing,create some of the 'bumps' in the image.
If you can find a large,clean image of this dimension of 'teardrop',it's what you're looking for.
FS: All USED Honda Insight Parts For Sale Fabio For Sale 17 06-16-2013 03:49 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 12:59 PM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 07:35 PM
Designing a tail extension for the first-gen Insight RobertSmalls Aerodynamics 187 07-11-2010 11:44 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
