Old 04-16-2008, 10:27 PM   #8 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by AndrewJ View Post
Let me know if you find something that works.
Will do. Right now, I'm in Columbus, OH driving an Altima 2.5 CVT -- but back home tomorrow night / late. Friday I'll have some time to test it out.
The plan is to pull the WHT/BLU wire mentioned and see if it starts (and if a CEL is thrown). If it fails to start, then I may be onto something -- then I'll splice into it and test an idle-cut and check for CELs. I still have a switch wired-in from a failed cylinder deactivation test a couple years ago -- so that can act as the test switch.
EDIT: The TDC/CKP/CYP sensor seems to have separate wiring from the shop manual...
Thanks to MetroMPG for the insight into a (potential) CEL free cut
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
