Old 12-25-2012, 12:56 PM   #28 (permalink)
MetroMPG
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Welcome to 3 cylinders! Learn to downshift if you need power when you're cruising at low RPM/top gear.
Get the car into VTEC mode (above ~2500-3200 RPM) and you will notice considerably more power available (relatively speaking) when the 2nd intake valve comes online.
Blackfly has ~50 hp, less torque, no VTEC, worse aero and weighs the same as the Insight.
