Old 07-01-2016, 03:07 PM   #16 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by Baltothewolf View Post
How did you do your kill-switch?
I basically did what was recommend at InsightCentral. I wrote a bit about it but I think I just posted on an existing thread there.
Two key components:
1) Clutch switch hack. It fakes the clutch being depressed. If not activated, the IMA system restarts the engine when it recognizes that you're rolling.
2) Fuel injector kill. This involves getting to the three + wires that power the injectors, under the little plastic cover that protects them.
I patiently figured out how to pop the cover open without destroying it. You sever each of the three wires and insert a relay in the circuit between them. They are all powered + 12V continuously, so you just splice together the three severed + wire ends, and the three other ends that go to the three injectors. Insert a relay between them and there you go.
Easier said than done, of course.
I made one circuit change vs. the procedure given in IC. I didn't like the idea of powering the relay's coil from the 12V injector circuit. I don't know what the coil load is vs. the load presented by the injectors but it certainly isn't exactly the same. So I powered the relay's coil from the 12V battery, via a little fuse.
I didn't tackle putting the switches themselves at the shifter. I mounted them in the pop out locations left of the steering wheel, near the storage bin. Not quite as convenient as the shifter location but it was easier for me to do - and looks very clean.
Coast long and prosper.
