Old 11-26-2007, 11:32 AM   #202 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
12-27-2006, 11:13 Am
Miscellany:
- Calculated the motor RPM in the video: 1387. Compare to about 2200 on the bench when not spinning the drivetrain (which has no oil in it).
- Details on the brush timing adjustment:
Above, you see a few things:
- The new set of bolt holes on the end cap (very top) which anchor the brush plate. The new holes are oblong, so some fine tuning is possible.
- The total brush adjustment was a combination of rotating both the brush plate PLUS the end cap, and you can see the old end cap bolt hole on the bottom side of the brush window.
- Lastly, I made a couple of new mini bus bars to attach the heavy field wire to the brush plate. Old bus bar sitting on top; new one shown connected in the brush window.
Above: one of the end cap bolts in its original location was snug against the left side of this brush window openings. I needed to make a little cut-out to accomodate the new hole. Easy as pie: the end cap is aluminum - so easy to cut & drill.
Don't think I posted this yet: motor in the car.
