Old 04-22-2018, 07:47 PM   #52 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
The fan is electric. 40% is okay for blocking, and temp should trigger the fan. On long hills temps will jump a bit. In such a situation you might turn the cabin heater on full blast. Also, on my 1998 a setting that helps a lot in normal conditions and uses no energy: temp selector on hot, fan off, internal air circulation selected. Amazingly, the coolant runs thrpough the cabin heat exchanger but the hot air does not come into the cabin.
Do you have a way to monitor temps accurately (not the OEM gauge)?
