09-17-2017, 04:18 AM
#11 (permalink)
I know this is probably a super long shot but does anyone have any information on the temperature sensors used in the large rear tesla drive unit? I have measured room temperature resistance and observed the resistance drops with increasing temperature but that's it. My plan is to start running coolant through the motor / inverter and plot a few points of resistance versus temperature. Any help much appreciated
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
09-17-2017, 08:16 AM
#12 (permalink)
www.evbmw.com
09-17-2017, 11:36 AM
#13 (permalink)
Sorry - no direct knowledge here!
Much of industry just uses 100 ohm platinum RTDs. Based on the required temperatures (-40C -> 110C or so) it is the easiest. Do you have 2-wires or 3?
The other common sensor based on the temperature range is J type thermocouples. Those are different - they generate a small voltage difference from dissimilar metals welded together. You almost need to bring the signal into an op-amp to measure it.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
09-17-2017, 01:01 PM
#14 (permalink)
Thanks for the support guys.
Well, thank you for supporting Ecomodder. That you would post here is a good testimonial.
I will watch the back-and-forth between you and thingstodo with interest. The Tesla drivetrain replaces the Chrysler slant-6 in my motorhome design.
09-18-2017, 10:57 AM
#15 (permalink)
Started getting to grips with the front drive unit board today for a few hours. Current sensors are plain vanilla analog and output +/- 2mV/Amp and sit on 2.5v at zero current. Was a tour de force to get the pcb off. Had to use the hot air station to melt the solder on the current sensors. Anyway , got it without damaging the sensors and started getting the pcb outline and locations in progress.
I'm getting together quite a collection of "scrap" Tesla logic boards
www.evbmw.com
09-22-2017, 01:59 PM
#16 (permalink)
On the subject of small motors , I got the pcb footprint sorted today. I've uploaded a dxf over on github for anyone interested. Schematic in progress.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
09-23-2017, 06:32 AM
#17 (permalink)
So working on the front drive unit logic board. Right now , I have most of the functions of the 24 way interface connector from the logic to the driver board worked out but there are a few I'm not sure about. Have a look at the attached pinout and tell me what I'm missing
www.evbmw.com
09-23-2017, 12:29 PM
#18 (permalink)
Very tight on board space with this one
www.evbmw.com
09-25-2017, 11:30 AM
#19 (permalink)
So I completed the layout of the small front motor logic board today. Going to wait a week or so before ordering boards as it's not a question of if I have made mistakes just how many. Not sure if the logic boards are the same in the small front and rear motors as yet.
Schematics and some support files are up on the github. I won't release the pcb files until I at least make sure I'm not shorting out the 12v supply
www.evbmw.com
09-30-2017, 11:39 AM
#20 (permalink)
Had some fun figuring out the large drive unit temperature sensors today
www.evbmw.com
