Old 10-02-2017, 05:04 AM   #21 (permalink)
jackbauer's Avatar
Design files for the small drive unit open source logic board version 1 now released on github : https://github.com/damienmaguire/Tesla-Front-Drive-Unit
PCB order going in today.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
thingstodo (10-02-2017)
Old 10-02-2017, 12:15 PM   #22 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Keep up the good work
Enjoying the updates!
Still can't figure out where you get the energy to keep plugging away at this project. AND all your other projects.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 10-19-2017, 02:21 PM   #23 (permalink)
jackbauer's Avatar
Perfect fit The small drive unit pcb lines up perfectly with the mounting holes , current sensors and power stage connector.
Name:	2017-10-19 19.04.40.jpg
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
roflwaffle (11-07-2017), thingstodo (10-28-2017)
Old 10-28-2017, 11:08 AM   #24 (permalink)
jackbauer's Avatar
Front drive units spins for the first time today with the V1 logic board. Will be doing more testing over the next few days including closed loop and high voltage runs. This board will run both front and rear small motors.
Name:	2017-10-28 15.20.35.jpg
ID:	22885   Click image for larger version
Name:	2017-10-28 14.18.19.jpg
www.evbmw.com
Old 10-28-2017, 12:18 PM   #25 (permalink)
jackbauer's Avatar
www.evbmw.com
roflwaffle (10-28-2017), thingstodo (11-10-2017)
Old 11-04-2017, 03:51 PM   #26 (permalink)
jackbauer's Avatar
www.evbmw.com
roflwaffle (11-07-2017), thingstodo (11-10-2017)
Old 12-04-2017, 05:21 PM   #27 (permalink)
Have you purchased individual parts to dissect them?
https://jalopnik.com/mercedes-parent...tes-1820961392
