Old 11-13-2016, 01:12 PM   #41 (permalink)
Enki's Avatar
Beggers can't be choosers. I'll take the ethanol I can get (and already have access to).
Old 11-13-2016, 04:53 PM   #42 (permalink)
Enki's Avatar
I double checked and I stand corrected.
Shell off Houghton and Valencia tested E88 10/25.
Old 11-13-2016, 07:51 PM   #43 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
There's a lot of misinformation out there about the "dangers" of ethanol. Lest we forget it is a direct competitor of big oil and requires essentially 0 modifications.
Old 11-13-2016, 09:14 PM   #44 (permalink)
Enki's Avatar
To make it efficient (hopefully more efficient than gasoline), you do need modifications. Fortunately, I stand to prove that with the engine rebuild I'm doing.
Old 11-14-2016, 02:43 AM   #45 (permalink)
Beyond TLC - '89 Volkswagen Golf Syncro Gti
90 day: 26.78 mpg (US)
Gypsy deathtrap - '96 Seat Cordoba Tdi
90 day: 63.56 mpg (US)
Pinky - '00 Opel Corsa
90 day: 39.29 mpg (US)
corsavan - '11 opel corsavan
90 day: 52.41 mpg (US)
cordoba - '01 seat cordoba estate
90 day: 39 mpg (US)
In cold weather it can drop to as little as 70% alcohol, the rest petrol, and yet the price stays roughly the same. So more energy for the same money!
To the OP: are you planning any engine mods to take advantage of the e85's higher octane?
The Following User Says Thank You to syncro_user For This Useful Post:
Enki (11-14-2016)
Old 11-16-2016, 08:48 AM   #46 (permalink)
Rogue Engineer
The next thing I would do is advance the timing. I don't have control of that in my car. I have a mega squirt 3 that I put together and got running. I did some of the sensor calibrations... but I've forgotten what went wrong and why its sitting on a shelf. It was several years ago now. I do remember getting hung up on cam/crank sensor.
To Enki, what engine/vehicle are you using? sounds fun. I think some of the newer motors are well suited for it off the shelf, like the chevy ecotec. Seems like GM got whipped into shape pretty good.
Old 11-16-2016, 11:32 AM   #47 (permalink)
Enki's Avatar
It's a 2009 Mazdaspeed 3, but that's about all that's the same engine wise. I'm destroking it down to 2 liters (from 2.3) and making up the difference with rod length, and upping the static compression from 9.5 to 12.5 (the pistons would be 14:1 stock stroke).
I was able to get about 27 MPG on stock engine with a 50/50 mix previously (highway), but with the changes I've made to the engine I hope to get that up over 30 on full e85 in the future.
Old 11-25-2016, 07:20 PM   #48 (permalink)
Around here standard unleaded can be up to 10% ethanol . I thought E85 was 15% ethanol . Is it 85% ethanol ?
Thanks ,
Wyr
God Bless
Old 11-25-2016, 07:47 PM   #49 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Thanks ,
Wyr
God Bless
Lol e15 is 15%
Old 11-25-2016, 08:16 PM   #50 (permalink)
Well , that shows you how much I do not know ! :-)
Thanks for setting me straight .
God bless
Wyr
PS So , flex fuel cars & pickups will do 85% ethanol ?
2001 honda civic dx, d17a1, e85, high compression, rsx-s injector
