09-01-2020, 10:46 PM
#101 (permalink)
Leaf logging.
The leaf is a good mild logging vehicle because it can drive to the cutting site at 30 mph then drag hundreds of pounds of logs back at 13mph while plowing a 6 inch deep trench.
It also could have powered the electric chain saw.
The Following 3 Users Say Thank You to oil pan 4 For This Useful Post:
09-01-2020, 11:44 PM
#102 (permalink)
those batteries provide traction in a couple of ways
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
09-02-2020, 10:48 AM
#103 (permalink)
Leaf logging.
Crazy Cool!
09-02-2020, 12:33 PM
#104 (permalink)
09-02-2020, 01:07 PM
#105 (permalink)
Originally Posted by redpoint5
A very intelligent (and opinionated) man.
His knowledge and wisdom will be missed by me and others I know.
The Following User Says Thank You to ldjessee00 For This Useful Post:
09-02-2020, 07:21 PM
#106 (permalink)
Growin a stash
I enjoyed his videos. RIP.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
09-29-2020, 12:46 PM
#107 (permalink)
More leaf logging. The leaf hit nearly 40kw trying to break this one free.
I was out there dragging rotten wood to the burn pile for brush and large solid trees to the fire wood pile.
09-29-2020, 01:02 PM
#108 (permalink)
Every had any trouble with your Leaf's 12v battery?
Asking for a friend (literally).
09-29-2020, 02:35 PM
#109 (permalink)
Not yet but the 12v batt causes a lot of problems that you would never expect to be linked to the 12v system.
09-29-2020, 05:34 PM
#110 (permalink)
All the wonders a solid 8 volts feed will do for you cars electronic systems...
My Insight had a bad battery and it caused a whole flotilla of warnings and errors: VSC, hybrid battery, airbag, PS, you name it.
Turns out one of the 6 cells was slightly less charged than the others. So when the car charges the 12V batteries the other 5 cells hit full while the 6th isn't.
Due to the smartness of the engineers nowadays, the charging system won't keep pumping electrons into a fully charged battery; it would only waste power and shorten the lifespan. But it cannot detect that one of the cells is not really full yet.
The problem with lead acid is that self discharge increases when the cell voltage drops. Once out of line, and barred from pulling up by the other cells, it gets more and more out of line until it is nearly empty while the rest is full.
Then if you don't drive for a week or run a light for a while the bad cell gets fully discharged and may even invert while the other cells keep cranking out power. The 12V battery is now an 8 Volt battery...
I tried to recharge my battery with an Optimate 4 desulphating trickle charger. But it would only do 20% or so before cutting off. On discharge the 35 Ah battery could only sustain 400 Watt (33 Ampere) for 5 to 10 minutes before it died. When recharging it cut off again after taking only say 8 Ah.
Then I hooked the battery up with the 16V leads of a power adapter of one of my prematurely dead HP printers, together with a shunt as the adapter would shut itself down over 3 Ampere charging.
The voltage stayed at 14.something while charging for many hours while the battery was overcharging, producing minute amounts of HHO from its 5 good cells. then quickly shot up approaching 16 Volt while the current fell. The last cell was finally brimmed.
That was some 4 months ago. The battery is performing well since.
