Old 04-19-2017, 12:02 PM   #1 (permalink)
Smile FORD CMAX driving for MPG's, Aero Mods and Hypermiling
Here are three videos for CMAX Hybrid improving MPG's and Aero Mods.
Let me know what you think. I have had two 68mpg tanks going across country up to 931 miles.
Paul
Old 04-19-2017, 12:24 PM   #2 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 16.41 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One - '24 Hyundai Ioniq 5 SEL
90 day: 97.44 mpg (US)
This is my data sheet for a 1,000 mile plus run between refueling for our Ford C Max Energi which has a 20 mile range on electric drive only. In it I compare the ICE and the EV efficiencies, then at the end I report on the system using 1/3 ICE and 2/3rds EV.
1,011.6 miles 671.4 EV mi 66.37% 340.2 ICE mi
104.7 mpg 162 kWh 199.26 kWh 6.079 gals-e
(97.62 mpg actual gasoline 10.362 gals/April 11th, 2017)
10.362 gals + 6.079 gals e = 16.411 total system gallons
EV 671.4 ev / 6.079 gals ev = 110.445 mpg ev
ICE 340.2 ice / 10.362 gals = 32.831 mpg ice
PHEV 1011.6/16.441 gals e = 61.53 system mpg e
1,000/1011.6 = .988533 MBTU’s
1,000/663.7=1.5067 x 6.008=9.052 g-e = 1.01236 MBTU
1,000/336.3=2.973 x 10.243=30.452 gal= 3.40562MBTU
EV 9.052 gal x 32,777/miles = 297 watt hrs. Per mile
ICE 30.452 gal x 32,777/miles= 998 watt hrs. Per mile
EV cost $15.94 per mile $.023 per 0.1K mi $2.37 per 1K mi $23.74
ICE cost $22.79 per mile $.067 per .1K mi $6.69 per 1K mi $66.99
Cost / MBTU / kWh’s normalized per 1 K mi 1/3rd ICE and 2/3rds EV
EV $15.86 .6749 MBTU 198 kWh’s [totals $38.19, 1.8101 MBTU]
ICE $22.33 1.1352 MBTU 332.6 kWh’s [total 530 kWh’s per 1 K mi]
16.1698 system gallons e, 61.53 mpg e composite average.
Old 04-19-2017, 02:09 PM   #3 (permalink)
How to drive a CMAX/FFH to get great gas mileage.
WOW! To much info, LOL
For me it could have been easy to give you a Link: but the FORDCMAXHYBRIDFORUM.com is down.
So here's the Numbers: 931 miles, 656 EV miles(70% EV), 13.7 gal. and 68 mpg.
Paul
Old 06-05-2017, 02:16 PM   #4 (permalink)
I am noticing the Garage Fuel logs produce Kwh and watts per mile, but when I did the math it looks like they are using 33.7 kWh for a gallon of gasoline. While that may be a figure reported for gasoline it is not true for E-85 gasoline which is predominantly what is available here in southern New Mexico. E-85 gasoline has 111,836 BTU's per gallon which is equal to 32.777 kWh. I would have to use a .9726 multiplier to adjust the figures in the gas logs for kWh's and watts per mile.
Old 06-05-2017, 08:51 PM   #5 (permalink)
Pretty sure you mean E-15.
Old 06-06-2017, 09:30 AM   #6 (permalink)
Strange, I never noticed E-85 as standard and won't use it. I use Premium 91-93 octane which improves MPGs. Stopped in Los Cruses, NM Loves station last year and I don't remember them having E-85.
Old 06-06-2017, 10:52 PM   #7 (permalink)
Yes your right E-15 which is 85% gasoline. If the manufacture recommends 87 octane then that is good enough for me. This gasoline is rated at 111,836 but per gallon.
Old 06-07-2017, 10:17 AM   #8 (permalink)
Minimum octane for CMAX is 87, max ethanol % is 15 and regular in NM is 86 octane, I use Premium 93-91 octane.
Paul
Old 06-07-2017, 10:29 AM   #9 (permalink)
I can get 87 octane at Valero stations here. Paying 40 or more cents for premium gas makes no sense to me when there is no real benefit. This is all Ford recommends so it will do. Because of our higher elevation 86 octane is actually okay.
Old 06-07-2017, 10:56 AM   #10 (permalink)
Premium is worth 1-2 mpg for me, not quite worth the extra cost, but I like the extra range I also have 2016 F150XLT SC 4x4 2.7L EB with 23.3 mpg mostly HWY 15k mi., with 36gal tank, I use regular.
Paul
cmax
