05-04-2017, 04:58 PM
How not to trailer
Some people may have taken this post too seriously or didn't bother to read and comprehend the OP:
http://ecomodder.com/forum/showthrea...uck-25485.html
I'm not saying you can't tow a trailer with a prius.
But you don't want the police man telling you not to tow your jeep with a prius on a tandem axle trailer and cutting you a fat ticket.
That's at least a 1,200lb to 1,400lb trailer when it's empty.
Then the jeep has to weigh at least 4,000lb.
I doubt the prius has a brake controller.
I'm sure that's at least double the prius tow rating, if it has one.
Just because you have a pickup
https://www.youtube.com/embed/rJuoc0OpxRE
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
05-04-2017, 05:47 PM
Focused on MPG
Nah....put that prius in L mode and charge the battery in no time!!!
Staying Focus'd on MPG
05-04-2017, 09:48 PM
Waaay too much tongue weight. Couldn't even get that right.
05-05-2017, 02:29 AM
I can understand someone hooking it all up just to see how it would look and to move around the driveway/private road. But any idiot could tell you that actually driving something that looks like that on the street makes you a menace to society.
I wonder just how overloaded that poor Prius is.
05-05-2017, 10:29 AM
Rat Racer
I'm amazed the front tires had enough grip to move it.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
The Following User Says Thank You to Fat Charlie For This Useful Post:
05-05-2017, 01:49 PM
This is why I would be hesitant in buying an ecobox with a hitch. Bad choices are pervasive when people just don't know the difference.
This poor car will need an alinment after this torture. As the suspension is completely bottomed out, the only thing left to suck up the bumps is bending the sheet metal chassis. There lucky they didn't push the struts through the mounts and out the side windows...
Dreem big chisel down to reality.
In this case its better to just start with a new rock.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
05-07-2017, 11:05 AM
Aren't there maximum towing weights in the USA?
05-07-2017, 11:58 AM
Most cars in the United States come with factory recommend tow ratings, then the hitch you install also has weight ratings (because cars don't come with towing gear). Then you use which ever is lower.
The car may have a 2,000lb tow limit, the hitch may one be rated for 1,000lb. Or the car may have a 1,000lb limit but the hitch may have a 2,000lb limit. You have to go with the lower rating.
Then you have trailer limits and tire limits of the vehicle and trailer tires.
05-07-2017, 12:31 PM
#9 (permalink)
They probably only stopped the Prius because the taillights on the trailer didn't work. LOL
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following 2 Users Say Thank You to me and my metro For This Useful Post:
05-07-2017, 12:32 PM
#10 (permalink)
Aah okay, so it's about the same as in The Netherlands. The Prius anyway, isn't allowed to tow anything here. The hitch may only be used for a bicycle carrier.
