Old 06-28-2017, 12:48 AM   #51 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
When I lowered my 91 with the Swift GT springs I removed the bump stops. To do it over I would have left about 3/4" at both ends.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
MetroMPG (06-28-2017)
Old 06-28-2017, 08:52 AM   #52 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Thanks for the tip, me & my Metro. I'll probably have these out again to clean them up (paint), and can do that mod.
Old 06-30-2017, 01:04 PM   #53 (permalink)
Yet another observation from lowering
5) Because the Flea now has race car suspension, I may have glimpsed a dashboard light that I've never seen before!
I saw something come on briefly during a quick, sweeping corner. It was too brief to know what the light was, but it was near the fuel gauge, and the needle is currently near E.
I've never run this car out of fuel before, so I've never seen a low fuel light. But the owner's manual says the car "may" have one.
Old 06-30-2017, 02:04 PM   #54 (permalink)
...beats walking...
Sounds like the GM "low fuel" indicator used to alert the driver that soon they'll be walking...and...likely replacing the "in-tank" fuel pump which relies upon the fuel as coolant.
Old 06-30-2017, 03:54 PM   #55 (permalink)
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
I know I don't have a warning light... But then again, I've never driven it that low either, It reads EMPTY @ 8 gallons, and its hard to gauge how much I have left after that, plus the cooling effect is needed... So I've always had an effective range of only 8gls... But I'm pretty sure I don't have an indication light.
Highest Tank To Date = 67.5 MPG
Project Goal = 100 MPG (67.5% there :-)
Old 06-30-2017, 04:33 PM   #56 (permalink)
While the tank is low, maybe I should just jack up the appropriate side and see if that reveals the mystery light.
Old 06-30-2017, 04:38 PM   #57 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
I don't believe they have a low fuel light...unless it's something restricted to 98-up models. Maybe it was your oil light? Though you'd really have to be cornering hard to manage that...
Old 06-30-2017, 06:06 PM   #58 (permalink)
In a Beetle, if a light comes on in a corner, it's the oil pressure warning light.
Old 06-30-2017, 06:09 PM   #59 (permalink)
That was actually my first thought, but it was in the wrong place to be the oil light.
Old 06-30-2017, 07:10 PM   #60 (permalink)
Stubby79's Avatar
brake light (low fluid) comes on in my firefly when I go sliding around a corner...
The Following User Says Thank You to Stubby79 For This Useful Post:
MetroMPG (06-30-2017)
