Old 05-04-2015, 01:27 PM   #21 (permalink)
Supra - '88 Toyota Supra
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 24.43 mpg (US)
Golf - '03 Vw Golf
90 day: 38.57 mpg (US)
Looks like a neat and cheap project. Did you notice a gain in fuel economy and or more stability going down the road?
Old 05-05-2015, 05:49 PM   #22 (permalink)
intended function
Hi folks,
Can I ask what is the intended aerodynamic function of these side skirts?
Personally, it feels a bit counterintuitive -- I would think that you want to have air "escape" out from under the car; and not to trap it under the car. And none of the ultra-low Cd cars that I am aware of have anything like this.
They're borrowed from racing where they segregate the flow between sides and bottom (as pickups are using step rails today),making a 'flush' pathway for the air across the tires.Sometimes,air fence flow straighteners are added to keep the air moving longitudinally,not transversly).
The John Shinella' Trans Am Firebird units were shown in the Lockheed tunnel to cut drag.
Lower skirts have been used in ground-effects cars,but I don't think there's a drag advantage.
IMHO I would not have them lower than the belly.I used them on the CRX
BamZipPow (05-06-2015)
Old 05-06-2015, 03:24 AM   #23 (permalink)
VanDelay - '89 Ford Econoline E-150 XL
90 day: 15.93 mpg (US)
Old White Civic - '98 Honda Civic LX, AT
90 day: 33.18 mpg (US)
...Sometimes,air fence flow straighteners are added to keep the air moving longitudinally,not transversly)....
I'm listening
The Following User Says Thank You to mwilliamshs For This Useful Post:
aerohead (05-06-2015)
Old 05-06-2015, 05:59 PM   #24 (permalink)
straighteners
Originally Posted by mwilliamshs View Post
I'm listening
The 1987 Olds AEROTECH would be an example
http://deansgarage.com/wp-content/ga...n_at_speed.jpg
A bunch of Pontiacs had these as styling features.
BamZipPow (05-06-2015), Tango Charlie (01-11-2016)
Old 05-06-2015, 07:34 PM   #25 (permalink)
3800
Team Saturn
Sports Cars
Team Ford
Pickups
Golf - '03 Vw Golf
I want one
Old 05-06-2015, 08:32 PM   #26 (permalink)
are the straighteners the horizontal surfaces (and the transition to such) at the rear of the skirts?
Old 05-07-2015, 05:16 PM   #27 (permalink)
are the
Yes.They intrude into the airstream and create a physical boundary which directs the flow and helps isolate it from hostile pressure gradient across the 'border' which might otherwise induce a span-wise flow,spinning up into power-robbing vortices.
Once the flow is aligned with the fence,it builds momentum which tends to keep it moving in that direction.
Old 05-07-2015, 06:16 PM   #28 (permalink)
i got most of that...
the horizontal fins on the side skirts...
...They intrude into the airstream
They stick out from the car
and air can't go through them
so the air gets pushed by the fin
and this keeps it separated
from...????
once the air gets pushed by the fence
it keeps going that way
is that about right?
aerohead (05-07-2015)
Old 05-07-2015, 06:36 PM   #29 (permalink)
spanwise flow
Yep,you've got a good handle on it.
For the spanwise flow,here's a better explanation:
If the pressure below the car was higher than the pressure besides the car,the high pressure air would bleed up into the lower pressure air alongside the car,moving transversly,or,sideways (spanwise if on a wing).
This transverse flow spins up into vortices,as a fast-moving tributary meeting a slow-moving river,or as the jet stream spins warm,rising,moist gulf air over Colorado into supercell tornadoes.
The vortices lockup kinetic energy which can never be converted to pressure,ultimately raising the pressure drag.
If the fence can keep the two pressure regimes apart,we can skip the vorticity.
Winglets on commercial airliner wingtips are a form of exaggerated fence which helps spanwise vorticity from forming.
BamZipPow (05-07-2015)
Effectiveness of side skirts? fanamingo Aerodynamics 14 04-07-2022 01:57 PM
Temporary side skirts? atomicradish Aerodynamics 9 07-02-2011 06:52 PM
Finally Got Side Skirts Big Dave Aerodynamics 16 07-01-2009 10:03 PM
Side skirts? hamorhead Aerodynamics 6 09-16-2008 06:52 PM
Side skirts fastening tasdrouille Aerodynamics 9 08-01-2008 01:24 PM
