Old 01-16-2013, 07:31 PM   #11 (permalink)
darcane's Avatar
Originally Posted by Old Tele man View Post
...correct, the two bodys are totally different:
1969 is an A-body fastback.
1970 is an E-body notchback sedan.
While totally different, there wasn't that much design change related to aerodynamics in those years. I'd bet the CdA is only slightly different between the two cars in stock form.
I'd say the Blowfish vs SuperCuda is a fairly good comparison of how aerodynamics affects speed on similar cars with similar power...
Of course, it's also worth noting that the SuperCuda has been modified aerodynamically as well. It's been lowered and has a belly pan, splitter, and rear diffuser.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 01-16-2013, 08:26 PM   #12 (permalink)
...beats walking...
The 1969 A-body was narrower/taller and the 1970 E-body was wider/lower because it was specifically designed to accept the low & raised B-block engines 383, 440 and HEMI, which the A-body was NEVER (originally) intended to handle:
• 1969 A-body: 54.5"(h) x 70.0"(w), 108" wheelbase.
• 1970 E-body: 50.9"(h) x 74.9"(w), 108" wheelbase.
...although B-blocks were 'shoe-horned' into A-bodies by both owners and Corporate Plymouth.
Old 01-16-2013, 09:52 PM   #13 (permalink)
Here's a quick look at the two. The first is the same as the LMC car, and the second is like Poteet's car. I would go out on a limb and say that the 69 has much better aero than the 70, even in stock form.
Travis..
The Following User Says Thank You to crashnzuk For This Useful Post:
aerohead (01-17-2013)
super cuda aerodynamics
