Old 12-19-2023, 10:27 AM   #11 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I've removed my oem sound insulation from my hood, and threw on a sheet of standard craft paper backed r-13 over my engine from side to side. Makes a huge improvement in holding in heat. It would be on the prius when the engine would shut off the temp would go 1..2...3...4...5... essentially losing a degree a second (in 25-30F. Now with insulation it really doesn't lose it very fast.
It was pretty much impossible to stay in hybrid mode (above 150F) without. Now with upper and lower grill blocks, i can use a small amount of heat and get almost summer gas mileage in 45mph and down scenarios.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following 2 Users Say Thank You to hayden55 For This Useful Post:
Ecky (12-19-2023), Piwoslaw (12-22-2023)
Old 12-19-2023, 11:17 AM   #12 (permalink)
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
Originally Posted by twj347 View Post
Do you know what kind of aluminum bubble insulation you used, or what its temperature rating is? I looked into using this type of insulation before, but the stuff I found is only rated for temperatures up to 180 °F.
No idea. I don’t even think my hybrids engine bay can get that warm in cold months.
The Following User Says Thank You to Phase For This Useful Post:
Ecky (12-19-2023)
