Old 08-27-2009, 12:56 PM   #11 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
I think its a awesome idea, have the front hooked on from the inside, something that does not spin but turns with the wheel, like the brake caliper for example? and I think Wheel skirts for the rear would still be good... But this way there is no need for tring to find a solution to front wheel skirts and you can just have those turn with left or right with the wheel
Old 08-27-2009, 01:41 PM   #12 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
I like this idea. A lot of fabrication to get it right though.
Old 08-27-2009, 02:39 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Hello -
Similar to the wheel spinners, the Taxi "Cap-Ads" are an option :
Smooth rims?
Originally Posted by cfg83 View Post
ai_vin -
Oh yeah, I've considered those, but I think they are very pri$ey :
CapAds not rotating wheel cover - No non not rotating advertising media hubcap
This is actually the "effect" I wanted to create with my old SC2 back in the 1990's. I wanted to make it look like my car was "floating" over the road.
Because you are adding a heavy "weight" to the outside of the wheel (at least that's how I *think* it works), I suspect that the driving characteristics change.
By design, they use a weight to try to keep the image oriented. But they are also assuming the image does not extend past the wheel.
CarloSW2
American Solar Energy Society
Old 08-27-2009, 11:01 PM   #14 (permalink)
Gen II Prianista
Rokeby's Avatar
Symbiosis
Although made in different posts, all the parts for what seems to be
workable front wheel/fender skirts have been mentioned:
1. A non-spinning wheel disc with a center-point bearing attached to the
wheel for outside the wheel , non-permeable support and centering. But
instead of having the rough diameter of the wheel, it would be slightly
larger than the diameter of the tire, and even be rolled slightly
inward around the outer edge of the tire. The disc would be cut off on a
chord at the level of the rocker panels.
2. The wheel disc would also be attached to the spindle with three braces
that wrap over and behind the tire/wheel, one at the top, and two at
~+/-120 deg from the top one.
3. A flexible membrane stretched across the wheel opening.
In this way, as the wheel is turned side to side in tight turns, the non-
spinning disc contacts and stretches the whole length of the membrane.
Anti-turning force from the membrane against the wheel would be
minimized.
[EDIT: Small diameter rollers affixed to the inside of the disc might be
needed to keep from side loading the center bearing as the disc pushes
out against the membrane in turns. This is getting complicated.]
This I think, just might do the trick.
Of course, removing the rig to change a tire would be the devil's own
work!
Old 08-28-2009, 08:39 AM   #15 (permalink)
I think this idea has come up before. But what about a ring of brushes surrounding the front wheels, similar to what some busses and trucks use to cut down on rain spray?
McMaster-Carr has some strip brushes with a flexible backing. I still wonder how well they would conform to a wheel arch, though.
McMaster-Carr
