Old 12-10-2012, 11:31 AM   #131 (permalink)
Daox's Paseo - '97 Paseo
90 day: 36.6 mpg (US)
CM400E - '81 CM400E
Daox's Grey Prius - '04 Prius
90 day: 48.5 mpg (US)
Sadly, I didn't get around to bench testing the grill block this weekend. I ran into a snag. I was hoping to use a plastic flexible pushrod to actuate the grill block. These are the kind used on radio control airplanes and they look like the image below.
The problem is, that my bend radius is around 1" which is really tight. The plastic pushrod doesn't like to bend that tight. The outer tube ends up pinching the plastic rod inside and the door lock actuator won't have enough power to push it.
So, I'm now trying to think of other simple & cheap ideas here. If anyone is aware of a more flexible pushrod I'd love to hear about it. Otherwise I think I'm going to be stuck adding a 90 degree pivot arm to the assembly. It won't be expensive, but it will just add more complexity to the whole thing.
Doh, just had an idea while writing this. If I sanded down the inner rod it would have more clearance and would probably work just fine. I'll give that a try and see how it works out. Still open to other ideas though.
Old 12-10-2012, 01:38 PM   #132 (permalink)
Smeghead
escort - '99 escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Forester s
90 day: 28.55 mpg (US)
Bicycle brake/shifter cable and sheath?
Or use metal cable instead of the plastic push-rod in the same outer tube the short distance from the end of the housing to the actuator and the throw for the lever should be ok. You can use some heat with the cable in the actuator to get the bend with out the binding.
Edit, JBweld to secure the pushrod ends to the cable, and a drimel like tool to cut the cable without fraying.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 12-10-2012, 06:43 PM   #133 (permalink)
flexible push
My thought is that you're going to encounter binding anytime you 'push.'
This setup will be great for tension loads,but in compression,unless you had a mirror-image push-pull cable (as in an outboard motor steering system) it will tend to bind up inside the sheath.
In HVAC,rooftop package AC units have an outside air damper which is controlled by an electric motor and bell-crank which can rotate in either direction to modulate the airflow.
sjc123456789 (12-25-2012)
Old 12-10-2012, 09:18 PM   #134 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
A microprocessor can "drive" a stepper-motor BOTH forward AND backward.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
aerohead (12-12-2012)
Old 12-12-2012, 01:07 PM   #135 (permalink)
CM400E - '81 CM400E
I sanded down the pushrod last night. It seems like it should work. The next step is mounting it up.
Old 12-12-2012, 11:19 PM   #136 (permalink)
B.O. Zen
Pickup - '99 Tacoma 2wd, Regular Cab, Short Bed
90 day: 28.53 mpg (US)
Cool project... I'm looking forward to seeing how this works.
Old 12-15-2012, 09:00 PM   #137 (permalink)
ron
double eagles - '99 ram slt
90 day: 19.48 mpg (US)
Im in as well. ive had the bones for my CTD aero-nose cut for some time now and planned on a operable grill block of somekind ,this may fit the bill.
Old 12-17-2012, 08:08 AM   #138 (permalink)
CM400E - '81 CM400E
I worked on the grill block again last night. Its really starting to get near to its end form.
Here is a shot of the actual pushrods I used. I picked them up at a local hobby store. They're made for radio control airplanes. By the time I had sanded mine down those ridges were completely gone on the grey pieces. I only sanded it down in the area of the bend.
This is the first pushrod mounting piece. As you can probably tell, there isn't a ton of extra space to work with.
I had to file down the connecting piece between the two rods so it would fit around the hardware.
This is the other pushrod mounting point. It will make the 90 degree bend that is needed to get the pushrod out of the way of the actuating door flap.
And finally I threw the pushrod in to show how it'll be mounted.
ID:	12054  Click image for larger version
ID:	12055  Click image for larger version
ID:	12056  Click image for larger version
ID:	12057  Click image for larger version
Old 12-17-2012, 08:44 AM   #139 (permalink)
AndrzejM's Avatar
Mietek (wife's car) - '00 W168 classic
90 day: 41.01 mpg (US)
Berta - '97 318 tds Compact
90 day: 60.38 mpg (US)
Awesome! I can't wait to see it working.
Berta - modding thread
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 12-31-2012, 02:32 PM   #140 (permalink)
CM400E - '81 CM400E
I think its about time for an update. I took the time today to glue the pushrod to the brackets. I held the pushrod in place with a wire while the glue dried. Its still curing, so I don't know how well its going to hold yet. I still think adding another bracket on the long side is a good idea to stop the pushrod from flexing right at the glue joint.
Anyway, lets see some pics.
ID:	12150  Click image for larger version
ID:	12151  Click image for larger version
ID:	12152  Click image for larger version
actuated, ardunio, automatic, grill block
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
