Old 01-26-2009, 08:14 PM   #41 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
What are you guys using to draw in 3d with?
Old 01-27-2009, 07:04 AM   #42 (permalink)
I use SolidWorks, but thats because I get a copy through work.
Old 01-28-2009, 09:26 PM   #43 (permalink)
Alright, this is the part where I ask for help because I have no idea why my circuit doesn't work. From everything I can tell, the program is working perfectly and the circuit outputs exactly what I want it to. The leads from the h-bridge to the actuator sit at 0V normally. When I trigger it one way I get 5V. When I trigger it the other way I get -5V on my meter. Sounds right to me. However, when I hook up the actuator to the leads, it just kinda twitches and doesn't go in or out real far at all. The h-bridge is rated for 5 amps, so its not like it can't handle the power. I'm kind of at a loss here as my electronics knowledge is sorely lacking. I'm sure you'll probably need more info and clarification, so ask away.
Old 01-28-2009, 09:35 PM   #44 (permalink)
dcb
needs more cowbell
dcb's Avatar
is the actuator rated for 12 volts perhaps?
Old 01-28-2009, 09:39 PM   #45 (permalink)
When I hook it up directly to 5V it works just fine. I'm using an old computer power supply for my 5V.
Old 01-28-2009, 10:37 PM   #46 (permalink)
dcb
needs more cowbell
dcb's Avatar
What was the part number for the h-bridge? And what was the actuator out of?
Old 01-29-2009, 06:53 AM   #47 (permalink)
The h-bridge is a tle5205-2. I got it in the P-TO220-7-11 case if that matters at all. The actuator is a power door lock actuator out of some car. I got it from a co-worker for free.
Old 01-29-2009, 07:37 AM   #48 (permalink)
dcb
needs more cowbell
dcb's Avatar
I think you want to be putting 12 volts on the supply (Vs) on that h-bridge.
Computer supply should have one of those too.
Old 01-29-2009, 07:52 AM   #49 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
either that or switch relays with your output signal to switch 12v to the actuator, but seeing you have -5 +5V that might not be as straightforward as when you'd have two signals
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 01-29-2009, 09:50 AM   #50 (permalink)
OurInsight - '06 Honda Insight
Very interesting thread. I wish I had time to work on an active grill block. I have just done mine with tape on the top one on the Echo, and with removable screws on the bottom one. Keep a screwdriver in the car to remove the bottom one is Scangauge temp gets high.
jime
actuated, ardunio, automatic, grill block
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
