Old 07-25-2012, 05:12 PM   #1 (permalink)
Scandinavian creature
Golf ball - '94 Volkswagen Golf III
90 day: 28.46 mpg (US)
Around 30% more efficiency achieved and going :)
Well, i will post my results too in here
I started to use "Pulse and glide" driving style, after i installed the MPGuino.
I saw in real time how every driving style affects the economy, and realised that what driving school suggests for best economy, engine braking, is wrong.
Gliding in neutral saves most gas, and you have to use the brakes, that will also prevent the brake dragging in future.
And while running free with top gear, very little above 60km/h, uses no gas at all. That's useful sometimes.
Previously i have got highway consumption about 6,2l/100km, with normal driving.
With P&G, it's about 4,5l/100km, with accelerating and gliding between 80km/h and 100km/h.
Measured in about 20km trip, few times.
Next i'm going to make an EOC switch. I think it is done by cutting the hall-sensor signal, whick acts as kind of camshaft sensor at the same time. My Golf does'nt have cam sensor
And i should really calibrate the MPGuino better, since all i can do is calculate percents now.
Every time i have tried to calibrate it, either my girlfriend drives my car and starts it so weirdly that the trip meter resets, or the car gets broken. I swear someone will press the reset button or something happens next time and the calibration will go somewhere in the future...
Brrrmm
Now selling preassembled MPGuino's!
http://www.mthtek.net/mpguino/
Old 07-25-2012, 05:23 PM   #2 (permalink)
That is quite the improvement, nice job.
Old 07-25-2012, 05:43 PM   #3 (permalink)
My Accord - '95 Honda Accord 2.0is CC7 (european)
90 day: 36.2 mpg (US)
Very nice improvement! Hoping for something like that myself.
Was it hard to install the MPGuino on a car that old? My car is just as old and I concider bying one.
Honda Accord 1995 2.0is (european) manual gearing
EPA: 33 MPG / 7.1 l/100 km highway
Actual: 35,3 MPG / 6.7 l/100 km combined
Old 07-25-2012, 06:06 PM   #4 (permalink)
Well i think it was quite easy compared to other cars. This one is with one-point-injection, and the engine bay has lots of room, compared to Civic whick has no hole for fly to.. fly.
For finding the injection signal, i strongly recomment to just open the intake air box, that where the carburretor(or whatever you call it) is, and find where the wire goes from the injector.
On my experience, that where the MPGuino installation guide says "look for 12V", that is the voltage for the intake temperature sensor(NTC resistor), another is the other leg of that sensor, and two remaining, are plus and minus for the injector. You take the signal from the minus of the injector(the one going to the ECU).
THe VSS signal is quite straightforward, it's at the transmission box. Three wires, VCC/signal/GND. Easy to measure.
Brrrmm
Old 08-05-2012, 04:54 AM   #5 (permalink)
2,9l/100km achieved! aka 81 MPG
I installed the EOC switch, and made an 250km trip, with accelerating to 100km/h and EOCing to 80km/h.
The EOC technique hint i got works. start the car with only clutch, by rapidly releasing it, and instantly after that, press it back
Brrrmm
The Following 2 Users Say Thank You to Quezacotl For This Useful Post:
3-Wheeler (08-17-2012), redorchestra (08-05-2012)
Old 08-05-2012, 05:55 AM   #6 (permalink)
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
amazing
does my sig work now?
Old 08-05-2012, 11:25 AM   #7 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
WOW
With a 1.8L petrol car that's stunning !
Old 08-07-2012, 04:21 AM   #8 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Are you sure? before you said that mpguino is not calibrated and you only can use it for trends/percentages. Was that back-up'ed with refilling or just mpguino readout?
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
Old 08-07-2012, 04:29 AM   #9 (permalink)
I calibrated it some day ago. After that, i made the 250km trip
I did'nt calibrate it with full tank, about with 1/4 tank.
Brrrmm
Old 08-08-2012, 02:02 PM   #10 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I looked at your mileage log and saw the graph but no miles or gallons. What gives, is my computer broken?
Noah Webster, 1787
