Old 03-13-2008, 01:21 PM   #1 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
Foci - '03 Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
The AXe - SOLD - '97 Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
Automatic alternator cut out/regen braking
If the alternator produces parasitic drag when the field windings are powered up, but its not really needed to charge the battery, how about this for an idea?
A smart controller that cuts the power to the alternator's field windings in normal cruise or accel conditions, thus removing the electrical load on the engine caused by the alternator.
When decelerating (0% pedal and no fuel injected so 0% duty cycle) the alternator is switched back on and charges the battery at a high current, thus providing more braking effect.
If the battery voltage gets too low the controller can switch the alternator back in until its within a reasonable range again.
Any thoughts?
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
The Following User Says Thank You to AXMonster For This Useful Post:
rvind2008 (05-23-2011)
Old 03-13-2008, 01:24 PM   #2 (permalink)
All new BMWs have this.
http://www.greencarcongress.com/2006...troduces_.html
Pair it with a deep cycle battery and you have yourself a winner.
Old 03-13-2008, 01:25 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
This would be a real problem for us P&Gers haha.
The Following User Says Thank You to Daox For This Useful Post:
Old 03-13-2008, 01:37 PM   #4 (permalink)
AXMonster's Avatar
Shouldn't be as the charging wouldn't occur without the engine turning
I'm sure even the most hardcore P&Ger has to brake sometime??? LOL
Old 03-13-2008, 01:43 PM   #5 (permalink)
CM400E - '81 CM400E
I read the whole thing now. It seems the system monitors battery charge, so if you get low enough it should just kick in no matter what. But, normally its not charging during acceleration. When your P&Ging, your engine is only on when your accelerating.
Old 03-13-2008, 01:55 PM   #6 (permalink)
H4MM3R's Avatar
http://www.msdignition.com/2006/06-18.htm
http://www.msdignition.com/rpm_6.htm
http://www.msdignition.com/new_products/8940.html
These are links for switches that might work for you.
The Following User Says Thank You to H4MM3R For This Useful Post:
Old 03-13-2008, 01:57 PM   #7 (permalink)
AXMonster's Avatar
It would have to charge during accel if the battery got too low, well that's what I'd set my system to do
Old 03-13-2008, 02:12 PM   #8 (permalink)
H4MM3R's Avatar
On board battery charger. Keeps the battery fully charged. Link>>> http://batterytender.com/default.php...855899dc011c2c
Use only one deep cycle "AMG" battery for everything including starting.
I used this set up in 2003 Suburban worked great.
Old 03-13-2008, 02:19 PM   #9 (permalink)
AXMonster's Avatar
Ok, I have it sorted. Two systems required. First is the duty cycle switch system which will switch an output if a duty cycle goes above a set value. This would be set to 1% and then the output reversed (so 1 is 0 and 0 is 1). Therefore when the duty cycle drops below 1% then the alternator is energised. The reversing of the output could be simply done with a small relay.
Secondly there would be a voltage controller switch that cuts the alternator back in at a set voltage (say 11.5v) and then switches it off again at another value (say 12.5v).
These circuits are available here http://www.autospeed.com/shop/category_579/browse.html
Item numbers KC5375 & KC5377
Old 03-13-2008, 02:24 PM   #10 (permalink)
H4MM3R's Avatar
Nice link. Can't wait to hear how it works for you.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 09:29 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
Win an EM Sticker: guess Dad's mileage (Toyota Corolla automatic). Ends Jan 13. MetroMPG Hypermiling / EcoDriver's Ed 51 02-07-2008 10:02 AM
