Old 05-18-2017, 10:32 AM   #131 (permalink)
90 day: 39.62 mpg (US)
90 day: 41.67 mpg (US)
For now its slam bang. I'll add that to the code later once I get it functioning properly and get my open/close set points figured out.
Last night I got it hooked up and running. For a while I had some issues until I figured out I had the coolant temp signal coming into a digital pin instead of an analog pin. With that fixed, I tweaked the open settings and that seemed to get it working. Now, it should just be a matter of tweaking the set points. Though, I did have an issue this morning with it opening up right away. I'll have to look into that.
Current project: Heating the manual trans with engine coolant
The Following User Says Thank You to Daox For This Useful Post:
aerohead (05-20-2017)
Old 05-22-2017, 08:59 AM   #132 (permalink)
The grill block seems to be working pretty nicely over the weekend. But, I'm quickly finding out that I'm going to need an upper grill block to fully test out the piece. Without the upper grill blocked, it doesn't have much effect opening and closing it. So, I've started working on the upper grill block for the car. There is more info and pictures in my build thread for the car.
The Following 2 Users Say Thank You to Daox For This Useful Post:
aerohead (05-27-2017), Ecky (05-22-2017)
Old 05-25-2017, 04:04 PM   #133 (permalink)
Thalmaturge
Eeyore - '04 Honda Civic Hybrid
Go Pod - '00 Honda Insight AC
The Tinyvan - '07 Honda Fit Sport
Have I missed it, or is there an STL file somewhere in this thread?
Also: how have you mounted your coroplast? I see a reference to wood blocks...
Old 05-26-2017, 05:55 PM   #134 (permalink)
Grand Imperial Poobah
Shepherd777's Avatar
I could use a good way of making this connection water tight... Suggestions welcome!
I use these Delphi Weather Pack waterproof connectors on the big truck. They work great.
This place on eBay has them cheap and they ship fast.
prowireusa on eBay
Bob Sliwa
"Like a Midget at a Urinal, I knew I was gonna have to stay on my toes......."
http://www.airflowtruck.com
The Following 2 Users Say Thank You to Shepherd777 For This Useful Post:
aerohead (05-27-2017), Daox (05-26-2017)
Old 05-26-2017, 09:37 PM   #135 (permalink)
prowireusa on eBay
Wow, those are WAY more reasonably priced than I expected. Thanks!
Old 05-27-2017, 03:00 AM   #136 (permalink)
Yeah those are neice but you would have to cut the connector off the servo, and then the individual cables may be just a little bit too thin to provide a proper seal.
It will still be better than before.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
