Old 07-08-2009, 09:58 PM   #1 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Better aerodynamics, Less weight, More Style
Sometimes it's the little things that count right? I just took all the badges off my neon, Three "DODGE" signs & one "NEON" sign... Ok, the "less weight" is almost the equivalent to taking 1 cd out of my car but whatever~~ btw.... Can acetone mess up anything on my car to make me go 1mpg less? Look at my fuel log, ever since I used it~~and got crap results~~all logs after that have been about 1mpg less?
Old 07-08-2009, 10:17 PM   #2 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
Have you thought about reinstalling the letters to spell out wacky things, like "ODD EGG" or "ONE GONE" ? That would be fun.
I doubt that acetone did any damage...but how much did you put in?
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 07-08-2009, 10:23 PM   #3 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
So, you added it to your gas? Or you used it to remove the adhesive left behind by the badges?
I've added Acetone, Xylene, Toluene, Methyl Ethyl Ketone, and several other "bad" things to my engine before, because they were free and I knew I'd need gas before I could afford it again... none of them did anything to my MPGs, at least that I could ever tell from tank to tank measurements...
The Acetone may have (possibly) damaged a seal or something in your fuel system, so you may be leaking slight amounts of fuel, not enough to really know it.
Old 07-08-2009, 10:34 PM   #4 (permalink)
Steve - '92 Festiva
You could make the following words from these letters:
DDDDEEGGOON (all you have left that are still fully intact)
THREE LETTERS
DOG, DON, DOE, DEN, DEE, EGO, EON, GOO, GOD, ODE, ONE, NOG, NOD, NOE
FOUR LETTERS
DONE, DOON, DEED, EGON, GOON, GONE, GOOD, NODE, NEON
FIVE LETTERS OR MORE
DODGE (obviously), EGGED
If I find more, I'll edit. LOL.
Old 07-08-2009, 11:07 PM   #5 (permalink)
The Neon - '00 Neon
House of Tudor
I put about 1.8oz. to about 12.3 gallons of gas
Old 07-08-2009, 11:13 PM   #6 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
if you cut up the letters or turn them
you have Cs, Ms, Fs, Qs, etc
now, imagine the possibilites
Past Present Future?
Old 07-08-2009, 11:18 PM   #7 (permalink)
Steve - '92 Festiva
Back when I first joined this forum, I was working for a Union contracting company... I needed gas one day, and all I had was a 5 gallon can of Xylol (Xylene) in the trunk of my Civic.
On an empty tank, (Car wouldn't start again), I poured in about 2 gallons of the Xylol straight, so I could get into town to put gas in... about 35 miles from where I was, to a gas station I knew was still open.
I made it, and after putting 2 gallons of Xylol into an empty 12 gallon tank, and traveling 35 miles, it only took 10.75 or so gallons of gas to fillerup, which means I went about 35 miles on .75 gallons of Xylol, for a total MPG(x) of 46.4, slightly higher than normal, but I topped that tank off, and it wasn't an exact 2 gallon measurement of Xylol... so that can't be taken as gospel.
What I would guess happened, is that with the wicked timing advance that I had, I got more low-end torque from the Xylol's 114 Octane rating, which made it so that I could stay in higher gears for longer.
Old 07-08-2009, 11:22 PM   #8 (permalink)
The Neon - '00 Neon
House of Tudor
CHRIST, so you think there is no way the acetone damaged the car? Think I have just been doing something different that cost me 1mpg?
Old 07-08-2009, 11:25 PM   #9 (permalink)
Steve - '92 Festiva
I don't believe so, I can't imagine why that little would have done anything at all, (especially increase gas mileage... that stuff doesn't work, BTW), but again, I can't guarantee anything.
Like I said, the worst thing it would have done (Acetone is a great solvent) is destroy a seal somewhere that might be causing a vapor leak or even a mild liquid leak. Depending on how long it takes you to burn a tank, or how long between fill ups, you might see 1 mippig difference from any of those things.
Old 07-09-2009, 08:51 AM   #10 (permalink)
Deadly Efficient
A one MPG difference between a few tanks is well within the norm. I fill up at the exact same pump for every tank, always stop at the first click, and my tanks aren't even as close as yours. Your one MPG could be due to weather conditions, tire pressures, or who knows what. Carry on, friend!
-Terry
My Pet Threads:
acetone, aerodynamics, badges, damage, remove
I Bought the Geo Metro!!! Wayneburg EcoModding Central 12 07-22-2010 06:17 AM
Drawing a line for aerodynamics bgd73 Aerodynamics 5 02-17-2010 12:30 PM
Hexagonal Dimples as a way to improve aerodynamics Palionu Aerodynamics 29 10-27-2009 12:39 AM
Aerodynamics Seminar #1 - by Phil Knox MetroMPG Aerodynamics 5 07-12-2008 04:12 AM
Aerodynamics Seminar # 4 - by Phil Knox MetroMPG Aerodynamics 0 01-28-2008 08:36 PM
