Old 04-14-2013, 04:02 PM   #1 (permalink)
damunk
High Pressure/ Low pressure
I wanted to post on this site as I felt more technical knowledge here than the usual car forums.
Front fed induction.
I want to learn about how the low pressure zones can vary within engine bay all the way to and into a intake manifold.
Would A be better because air can flow right into and up to the intake filter without zero obstruction.?
Or B is better because the filter is close to the high pressure zone therefore will flow through quicker.?
Old 04-14-2013, 07:31 PM   #2 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Option c, throw that "magic" aftermarket device in the trash.
Old 04-15-2013, 04:20 AM   #3 (permalink)
damunk
Anyone here know a bit about high pressure to low pressure air travel. Would appreciate it. Thanks.
Old 04-15-2013, 04:30 AM   #4 (permalink)
If there's a throttle plate in there somewhere and you're going less than WOT and 150 mph, don't worry about it.
Old 04-15-2013, 06:43 AM   #5 (permalink)
B would probably be better because whatever the device is its going to cause some amount of resistance. So any low pressure would be spread over a larger area resulting in slightly higher pressure than A.
Old 04-15-2013, 07:21 AM   #6 (permalink)
damunk
Thanks KSA. Feels good to have alternative to option C.
Old 04-15-2013, 07:08 PM   #7 (permalink)
Testing would give you a much more solid answer.
There will probably be zero effective difference for the speed/load/RPM regimes that we generally care about. (E.g., 2000 RPM at 80% throttle.)
But again, testing it yourself would tell you.
-soD
