Old 06-05-2010, 03:37 AM   #1 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Bridgestone Ecopia EP100
Hello -
Saw a commercial for this and was curious :
The Ecopia EP100 is one of Bridgestone's ecologically oriented Grand Touring Summer tires developed for coupe and sedan drivers looking to combine traction, handling and comfort with reduced environmental impact. Ecopia EP100 tires are designed to enhance vehicle fuel economy by reducing tire rolling resistance along with the vehicle's carbon dioxide (CO2) emissions during operation. The Ecopia EP100 is designed for dry and wet conditions, but like all summer tires is not intended to be driven in near-freezing temperatures, through snow or on ice.
The Ecopia EP100 employs a tread compound that applies Bridgestone's unique NanoPro-Tech (Nanostructure-Oriented Properties Control Technology) to reduce rolling resistance and energy loss while maintaining wet traction. This compound is molded into a symmetric tread design featuring rib-linked blocks nestled close together to provide uniform footprint pressure combined with high-angle, lateral grooves to further enhance braking in wet conditions. The tire also features three-dimensional (3D) curves on the tread block surface to suppress noise generated when the block is in contact with the road.
The tire size/specs seemed limited (only one rated at 51 PSI), but the tread is intriguing and I always like Star Trekky words like NanoPro-Tech.
CarloSW2
American Solar Energy Society
Old 06-05-2010, 07:46 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Thats the tire I'm running on my Prius. I did have some normal cheapo tires the previous owner put on (non LRR) last summer and averaged about 55 mpg until winter. So far, it appears I'll be getting 58-60 mpg this summer. So, I'm quite happy with them.
Old 06-05-2010, 07:54 PM   #3 (permalink)
Tirerack.com did a LRR tire roundup. The ecopia placed near the top. When Round and Black Becomes Lean and Green I'll probably buy the Ecopia's to replace my OEM Dunlop 31's.
The Following User Says Thank You to flyer351 For This Useful Post:
cfg83 (06-11-2010)
Old 06-10-2010, 11:57 PM   #4 (permalink)
BigEco
Scepter Wagon Manual - '96 Scepter 2.2G SXV15
90 day: 27.41 mpg (US)
クレスタ - '93 Cresta Tourer S JZX90
90 day: 19.12 mpg (US)
That's what I'm going to put in my 17s. They are still wearing hi grip federals and GTs and have around 4 mm on them. It could be a year or two before I do the mod.
Old 06-11-2010, 04:51 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
flyer351 -
Ok, I used that article to make a comparison chart :
There are 7 tires, ordered from highest to lowest MPG.
Each tire gets points for it's rank.
If it's ranked first, it gets 7 points.
If it's ranked second, it gets 6 points.
The higher the number, the better the performance.
The tests are given equal weight.
In the above, the Yokohama has the highest total number of points, but ranks 3rd in MPG.
The Michelin Energy Saver, Ecopia, and Yokohama are the top-3 MPG tires.
The Ecopia is definitely becoming more intriguing to me.
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
Tango Charlie (06-12-2010)
Old 06-11-2010, 07:52 PM   #6 (permalink)
Interesting article, but I think one major problem with their results: the ScanGauge just isn't all that accurate in measuring fuel consumption, so their rankings could be way off.
Old 06-11-2010, 08:08 PM   #7 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...oh, the SG is accurate enough, but I doubt the test driver(s) are 100% perfect in repeatability...and certainly the daily weather isn't.
...and, were the vehicles warmed up to the exact same amount before EACH and EVERY test...I doubt it.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 06-12-2010, 12:25 PM   #8 (permalink)
Originally Posted by Old Tele man View Post
...oh, the SG is accurate enough...
Not unless they've improved it considerably since I bought mine.
But I agree about the driver/repeatability issues, and the other problems of trying to do a comparison of real-world driving in practical time. Much better to do rolling resistance in a lab, with sensitive equipment.
Old 06-12-2010, 05:15 PM   #9 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
Carlos, very cool graph! But I'm wondering how the prices compare between the tires. For me, cost is definitely a deciding factor.
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 06-13-2010, 01:12 AM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Tango Charlie -
That's fair. Here is the breakdown on tirerack :
$84 = Bridgestone Ecopia EP100 (Grand Touring Summer 185/65R15 88H)
$85 = Goodyear Assurance ComforTred (Passenger All-Season 185/65R15 86T)
$76 = Goodyear Assurance Fuel Max (Passenger All-Season 185/65R15 86T)
$69 = Goodyear Integrity (Passenger All-Season 185/65R15 86S) (*)
$122 = Michelin Energy Saver A/S (Passenger All-Season 185/65R15 86T)
$118 = Michelin HydroEdge with Green X (Passenger All-Season 185/65R15 86T)
$105 = Yokohama dB Super E-Spec (Grand Touring Summer 185/65R15 88H)
(*) - The Goodyear Integrity is the tire that was OEM on my Saturn S-Series and is the cheapest of the bunch.
CarloSW2
Tango Charlie (06-14-2010)
Woohoo! "Reserved" myself a set of used Insight tires (Bridgestone Potenza RE92) MetroMPG EcoModding Central 59 11-27-2011 01:01 PM
Talking to a Bridgestone engineer tomorrow - got questions? SVOboy EcoModding Central 26 03-19-2011 02:33 PM
Bridgestone Tires and LRR Old Tele man EcoModding Central 30 05-04-2010 12:31 PM
more mpg from bridgestone B381 moonmonkey EcoModding Central 0 01-19-2010 10:18 PM
