Old 02-02-2017, 10:24 PM   #11 (permalink)
Once the turbo is building up pressure, as a rule of thumb, a smaller engine that would otherwise be deemed underpowered and need to rev up higher to provide power and torque figures similar to a higher-displacement one can become more efficient. Now due to the widespread of direct injection, leaner burn can be implemented to go even further on fuel savings even though it might lead to an increase in nitrogen oxides (NOx) formation, which had been one of the Achilles' heels of Diesel engines. Cooling the air intake charge through a so-called intercooler or some water and alcohol injection is an effective way to deal with the NOx issue, and also to prevent knocks that would happen in a port-injected or a carburettor-fed turbocharged engine operating with a lean mixture at a high compression.
Old 02-10-2017, 05:28 AM   #12 (permalink)
NHB
Originally Posted by escymkii View Post
I was wondering n/a vehicles runs best at 80 percent load at around maybe 2000-2500 rpm. How about turbocharged gasoline engines? What if lets say at low RPM boost kicks in i believe entering into boost will require a rich mixture so will probably kill effeciency? so what is the "general rule" on these engines?
Modern turbocharged engines do not differ that much from naturally aspirated engines. There is not that much need for rich mixtures anymore. VW's latest engine 1.5 TSI (EA211 Evo) doesnít need rich mixture at all. It operates at stoichiometric conditions across the entire engine map. Fordís 1.0 Ecoboost, which has been around for some time already, uses just a bit enrichment at highest load when revs are 3600 rpm or more. 1.0 Ecoboost actually goes slightly lean when pushed hard at low revs.
I donít like general rules because there are so many different technologies on the market. Maybe one could say, that turbocharged engine have their most efficient point at slightly lower load point than n/a engines.
Old 02-10-2017, 08:28 PM   #13 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 43.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 34.78 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 36.47 mpg (US)
That doesn't explain why it's so freaking hard to match NEDC in a baby turbo and so freaking easy in a NA engine.
Old 02-11-2017, 05:36 AM   #14 (permalink)
NHB
I would say that all manufactures have learned to optimize their cars for NEDC test. Every new model has an unrealistic NEDC ratings. N/A engines are no different in this sense.
What makes you think that N/A engines don't have unrealistic NEDC ratings?
Old 02-11-2017, 09:15 AM   #15 (permalink)
Lada Fan
Fingie's Avatar
"The War Wagon" Aka Yevina - '03 Vaz 2111 1.5 8V Injected
90 day: 36.66 mpg (US)
T-D-I-C - '89 Volvo 760 Diesel Turbo Intercooler
90 day: 32.6 mpg (US)
my turbo-celica utilizes a twin-scroll turbo, it spun up pretty quick.
If drove with DWL, it seemed to make up for my quick accelerations, MPG-wise. At least a bit.
:/ dunno then how much i'd get out of it if I really tried to hypermile it
If you don't make any mistakes in your life,
life itself will be a f*ckup.
A V T O V A Z
Old 02-11-2017, 08:58 PM   #16 (permalink)
Team Turbocharged!
Pickups
Baby turbo engines have been built from the ground up to beat the NEDC test. Now that NEDC is being replaced with RDE there's a big scramble on to increase engine capacities. NA engines might be optimised for NEDC, but the scope of what can be done is far more limited.
I have/ have had ~10 cars over the last 3-4 years. 2014 Renault Kangoo 1.6NA, 300+ kg of cargo, roof rack, 600kg of trailer, and only on the very worst traffic days would it not match NEDC, but that was only ever by 0.1-0.3L. Without the trailer it would always hit NEDC within 2km in the morning and I'd pull up on a few occasions with the SG reading 100% over NEDC. I wonder what it would have done empty and without the roof rack?
Now the Kangoo was pretty much designed from the factory to be 100% EOC ready, so that's what I did (a lot), but I rarely EOC'd with the trailer as it would cruise pretty close to BSFC. In short even with a tiny 1.6 an extra ~1000kg, extra drag from a tall trailer and an extra set of wheels, NEDC was still easy to beat.
If Renault were trying to be unrealistic with the Kangoo they were doing a very poor job of it.
My baby turbo Fiat Twinair is only driven in pretty much ideal conditions (country trips on weekends) and has yet to match NEDC. EOC and P&G don't work as there's too much enrichment when getting up to speed.
My Renault Trafic 1.6 DCi is only new, but only just hovering around NEDC being driven on the same routes as the Kangoo. It has no roof rack and is currently carrying less than the Kangoo did, but there's no way I'd be beating NEDC with the trailer in tow.
With both of these baby turbos you really have to granny drive them on acceleration (NEDC style) to get good figures, suggesting they both do very early fuel enrichment. The NA engines are more fun because you can stomp on them a bit without an economy penalty. My average speed is 26km/h for the Renaults so it's a match for the NEDC 'city' figure. 100% of people with baby turbos including BMW's 1.5 triple seem to have the same experience.
Old 02-11-2017, 09:54 PM   #17 (permalink)
Would substituting some of the fuel injected with water produce the same effect as over fueling?
If so how much should the ecu be tuned down and the water added? And if water can be substituted for the fuel is it wise to up the boost?
Old 02-12-2017, 08:34 AM   #18 (permalink)
NHB
That Kangoo engine is an old engine from the time, when cycle optimization was not at the same level where it is now. If you take some more modern N/A engines, they are right there at the same level as turbocharged engines.
Your Fiat is notorious for delivering not so good real world consumption. It uses a lot enrichment. Some more advanced small turbocharged engines need very little enrichment or don't need it at all. For example small turbocharged engines from VW, PSA and Toyota are very efficient. Of course it's their NEDC ratings are unrealistic, but also new N/A engines are just as cycle optimized.
Downsized engines not going anywhere. Only small diesels have problems with their NOx emissions. The miller cycle has increased the size of few engines, but at the same time we have much more engines which are getting smaller.
Old 02-13-2017, 01:03 AM   #19 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Only if you can get the water to burn...
Old 02-13-2017, 01:37 PM   #20 (permalink)
Mazda 3 - '06 Mazda 3 iTouring
I was wondering n/a vehicles runs best at 80 percent load at around maybe 2000-2500 rpm. How about turbocharged gasoline engines? What if lets say at low RPM boost kicks in i believe entering into boost will require a rich mixture so will probably kill effeciency? so what is the "general rule" on these engines? and how about diesel? VGT engines turbo kicks in so early and from what i understand diesel is effecient when in boost? is this correct?
I ran my Volkswagen Passat 1.8 liter turbocharged engine really lean on the highway by using some diodes to fool the car into thinking it was at a normal AFR. I was able to get up to around 48 MPG in that car combined with some other mods like a front belly pan, more air pressure in tires, shaved antenna and a grille block. From the factory it got 29 MPG highway.
The diodes were to fool the ECU into thinking the car was getting less boost than it actually was, I used the wrong diode apparently and it kept it pretty lean.
Surprisingly, the engine is fine, the turbo is what blew up. But only because I forgot to put coolant in the radiator when it froze and the water never circulated into the turbo. Oh, and the fact it had the wastegate welded shut and no boost controller probably had something to do with it also.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
