Old 07-28-2008, 07:16 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
A/C Recirc
Not all of us have the fortitude to drive around all day withthe windows down, wspecially if we hit hwys. Therefore I have a question regarding a/c recirculation.
In another post someone mentioned how they P&G their a/c because of the drag on the motor, and I concur in my Vibe there is a 10mpg difference on the scangauge with or without a/c.
So I was thinking, since I do not use the 2 passenger vents in my car, would I gain any benefit from piping air from one of those vents directly in the recirc tube to get colder air in there and perhaps extending my non a/c use?
Things that you go hmmmm ....
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-30-2008, 04:36 PM   #2 (permalink)
-Bump- Anyone?
Old 07-31-2008, 04:51 AM   #3 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ranchero GT
Spaz - '83 S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
Uh..ohhh, sorry I was asleep.
Umm...I think it would work only the recirc part of the a/c is closed of when using the fresh air side. If you could manage to plumb it so it would work in the fresh air position it would most certainly work blowing more cold air on you.
Honda...the economical, renewable resource.
Old 07-31-2008, 06:38 AM   #4 (permalink)
Send a message via MSN to markweatherill
Block'em
I think simply blocking the unused vents would be better and easier.
Old 07-31-2008, 06:41 AM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I agree with Mark.
Old 07-31-2008, 09:49 AM   #6 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
If your goal is to extend your non A/C use, I would think that what's important is the average air temp in your car, in which case blocking/rerouting vents in recirc will change nothing.
They are currently running a set of articles at autospeed.com on new affordable electronic controllers they designed and now sell. It's interesting how using one of their module, one could use a thermistor to auto cycle their A/C.
www.HyperKilometreur.com - Quand chaque goutte compte...
Electric A/c conversion lovemysan EcoModding Central 15 08-28-2010 08:48 AM
Insulating cold a/c lines? CHEGAI EcoModding Central 18 06-30-2010 12:34 PM
Reduce A/C load by tinting your house windows! darkdan Saving@Home 7 07-08-2008 09:23 AM
a/c belt clutch on alternator? thecorrupterx Off-Topic Tech 3 06-20-2008 11:14 AM
It's not just the A/C tasdrouille General Efficiency Discussion 4 04-17-2008 11:57 PM
