04-01-2015, 11:42 PM
#11 (permalink)
Yeah my fuel gauge is far from linear also.
1998 LX with a full HX swap + VX transaxle.
04-02-2015, 12:31 AM
#12 (permalink)
Furry Furfag
Originally Posted by Chrysler kid
I'm at 275 sitting on the top side of half of a tank of gas. The needle tends to fall very quickly after half tank and I fill up at a quarter tank. I'm sure I would gain the most economy the less fuel I carry on board however I do not like the added stress and heat on the fuel pump. Im sure if I took out my two 12 inch subwoofers it would make a difference too lol.
I'm also running 10w30 synthetic, again I should switch to a lighter weight once summer hits full swing
Next tank I will try some marvel mystery oil. See if that snake oil does anything
The top half of the tank is around 7 gallons and the bottom half is somewhere around 4-4.5, that's why.
04-02-2015, 12:47 AM
#13 (permalink)
Fuel gauges are discussed here: 8 Gadgets That Lie to You Every Day | Cracked.com
In the last fifteen years, I believe that is the second comment I have read about only partially filling the tank in order to save gas. One gallon of gas weighs 6.073 pounds ( Gasoline - Wikipedia, the free encyclopedia), so if I only half-filled my 11.9-gallon tank, I would shed 36.134 pounds. My Civic weighs 2,519 pounds, so I would reduce the weight by 1.43%. The general rule of thumb is that for every 2% of weight you lose, you increase fuel economy 1%, so that would be ≈ 0.715%, and a 50 MPG tank would become 50.36.
Of course, we do plenty of modifications with smaller results.
04-02-2015, 01:05 AM
#14 (permalink)
This is all true.
I prefer to just fill it all the way up. I really hate stopping for fuel!
Once I know I have this gauge dialed in, if I see regular 45 mpg or more I am going to be very happy.
I am going to keep my eyes peeled for either a HX or VX transaxle.
Maybe I'll end up with both lol. I have EX and DX now already.
04-02-2015, 04:53 PM
#15 (permalink)
5 pin sensor
I use to own a mustang that would have squeaky shocks if the tank was less than half full.
At this time in our economy convenience>consumption so gas always full tank for me
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
04-02-2015, 06:46 PM
#16 (permalink)
I often have gas discounts, so I wait as long as I can to fill up. If I filled up twice as often, I would receive half the discount.
It is just a dollar here and there, but still.
04-03-2015, 11:02 PM
#17 (permalink)
hypermiler
MuleVX who has the best MPG on here always fills up every 3-4 days so about 1/2 tank. I'm going to try that method for a while because I just got 2 50mpg tanks in a row, but on a 1/2 tank fill I got 53. I'm thinking the extra weight is going to benefit my coasting, which is where I'm grossing the most gains. Plus I think Mule is on to something.
"I may be going to Hell in a Bucket, but at least I'm enjoying the ride." 🚗
04-03-2015, 11:42 PM
#18 (permalink)
Some people have different priorities in life.
For me stopping for fuel is a very low priority and one I really try to stay away from.
To me it's just not worth saving ~50 lbs to possibly get a couple extra MPG's.
EDIT: It would be ~36 lbs in my Civic.
04-04-2015, 09:36 AM
#19 (permalink)
5 pin sensor
If you really really want effecienCy you should map your route to expire at the gas station at the end of your commute lol
OG lean burn member
My civic thread
The Following User Says Thank You to Chrysler kid For This Useful Post:
04-06-2015, 01:59 AM
#20 (permalink)
One of my goals in life is to fill up as infrequently as possible.
