Old 10-09-2013, 03:45 AM   #11 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Subscribed!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 10-29-2013, 12:27 PM   #12 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
OK, the polycarbonate I ordered I got a deal on but I did NOT expect it to take this long to get here. I got a 2'x4' sheet which should give me enough to make the covers. It should be here this week. I'm actually considering using some of it if I have extra for a grill block. As on my current commute the thermostat never even opens and my mileage has been very poor as a result.
Could also use a block heater installed with winter coming up.
The Following User Says Thank You to brucey For This Useful Post:
aerohead (10-29-2013)
Old 11-02-2013, 10:28 AM   #13 (permalink)
A madman
brucey's Avatar
Lexan has arrived, however I made a mistake and ordered .030" thickness which I feel would be too flexible for this application. Sucks too, it's very strong/easy to work with.
For the time being I've used it as a grill block. Ordering more in something that is mostly solid disc instead of something paper thin. With the .030 even with 5 mounting points I'm not sure it would stay on the wheel at 45 mph.
How do you guys feel about 1/8" (.118 actual) thickness on these?
http://www.ebay.com/itm/4-SHEETS-OF-...-/221274905556
Would it be solid or would it be too flexible?
Old 11-03-2013, 07:36 PM   #14 (permalink)
Vex
Do these wheel covers cause issues with the brakes cooling?
Old 11-03-2013, 11:10 PM   #15 (permalink)
minispeed-Insight - '00 Honda Insight
90 day: 82.15 mpg (US)
MDX - '01 Acura MDX Touring
90 day: 22.29 mpg (US)
the wife's car - '13 Toyota Prius Plus
90 day: 45.99 mpg (US)
leaf-one - '15 Nissan Leaf SV
When I had the all black coroplast covers on my white kia I got a lot of compliments on them. This probably depends mostly on the colour of your car though, the kia was white so the contrast looked good, the same way a cop car looks good with steelies.
Old 11-06-2013, 01:43 PM   #16 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Doubtful considering the person driving it likely barely uses his brakes. I'm sure it would be a problem if someone else were to drive it in the mountains or in city traffic.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 11-08-2013, 07:55 AM   #17 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
solid black would probably look good on the black beetle as well. Hmm........
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 12-06-2013, 11:23 AM   #18 (permalink)
A madman
brucey's Avatar
Alright, lexan is in.
Next step: How to cut a perfectly round circle out of it.
I'm thinking of drilling a hole in the center and using a peg and bar attached to the jigsaw to go around. This will work for the inner one I think since I need to drill out the center anyway to fit between the hub/wheel.
For the outer one, I don't have any good ideas that keeps the disc completely smooth.
Old 12-06-2013, 12:11 PM   #19 (permalink)
...beats walking...
• MECHANICAL VIBRATION - A suggestion for minimizing the chance of mechanical vibration and rim flexing "breaking" the plastic: use the 'isolated-mounting' technique where you attach the plastic to the rim.
Specifically, place a rubber or neoprene grommet inside each hole, through which the mounting bolt or screw passes; and use a flat washer (between the bolt head and grommet) to spreadout the clamping force onto (first) the grommet and (then) the plastic. Thus, using the grommet as a flexible "vise-grip" to hold the plastic.
The Following User Says Thank You to gone-ot For This Useful Post:
mcrews (12-12-2013)
Old 12-12-2013, 06:06 PM   #20 (permalink)
90 day: 57.12 mpg (US)
Say what - I joined the fun!
I bought a 1/2 m by 1 m sheet of 2 mm thick Lexan for my upcoming aero projects, first and foremost of which were my aero wheelhub covers.
The hub covers themselves are nicely curved but have them big holes and dimples that need covering up:
As you can see the sheet of Lexan is covered on both side with a thin blueish protection foil.
We need to carefully pull that off the sheet.
Then drape it over the hub caps (it was just enough for the 4 of them):
Clean the hub caps beforehand and make sure they have double sided sticky tape on the back, like this:
Pull the sheet tight on opposite ends and press it on the sticky tape. Go round the cap pulling the cover evenly flat. Finally trim the excess sheeting so that it does not get in the way when remounting the cap.
The end result. The cover is blueish what corresponds well to the blue accents in the Insights headlights and windows.
Seen in the light of day:
[edit] Well it did look cool for a week or 2. Then it started to rip at the edges. It quickly wears through because the cap rubs on the rim edge. A small piece of rubber found its way though the rim and got locked under the foil, over time it would have grown worse.
It might have worked but was a FAIL.
The Following 4 Users Say Thank You to RedDevil For This Useful Post:
BamZipPow (12-12-2013), brucey (12-12-2013), California98Civic (12-13-2013), mcrews (12-12-2013)
