Old 10-18-2010, 05:51 AM   #1 (permalink)
1-ev.com's Avatar
Lightbulb Clutch Vs Clutchless
All know issues with downshifting Clutchless.
Hey engineers, do you think we can make controller work Clutchless with the button on the gear shifter?
It has been done on AC controller:
100% Electric '68 912, PCA zone12 proud member:http://www.goldcoastregion.org
Gold Coast Electric Auto Association proud member:http://www.goldcoasteaa.org
http://1-ev.blogspot.com/2010/10/starting-project.html
http://1-ev.blogspot.com/2011/12/1-e...-car-show.html
Old 10-18-2010, 07:55 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
it was sorta done there, looks like it is just a 1000 rpm command with that button, and not a full fledged shift synch. i.e. a button/combination of buttons/gate switches to tell it which gear you want next and it knows the speed of the car and the gear ratios and quickly brings the motor rpm to that speed. But yah that would make going clutchless a lot easier.
I think a rapid motor slowdown button would also help, but requires some driver skill on synching.
Old 10-18-2010, 04:07 PM   #3 (permalink)
jackbauer's Avatar
I don't have any problems with clutchless downshifting on the bmw. My guess would be it depends on the gearbox. The getrag is supposed to be good and so far i'm not disapointed. The procedure is use i , off pedal , neutral , then push the shifter into the required gate with moderate pressure. the synchros do their job and it slips into gear. Granted it requires a little more time and effort than a clutch system but with so few shifts required .............. just my 2c.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 10-18-2010, 06:13 PM   #4 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
Never had a problem just using my foot on the gas adjusted incrimentally by my brain :P
do it in diesel polos, formula ford race cars, Mercedes sprinter vans and everything between - even managed it on a in a non-syncho 50's morris!
you have all the tech at hand you don't need to add more
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 10-19-2010, 05:31 AM   #5 (permalink)
1-ev.com's Avatar
Hey guys,
The reason I think it may be a good idea that would be easy to drive for the person without “clutchless” EV experience. It would be close to driving a clutch.
Let say what if we want to sell EV ... Sorry to even say that :-)
clutch vs clutchless, dc controller, ev downshifting, ev shifting
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 08:52 AM
Freewheel Clutch: Lower RR LostCause EcoModding Central 8 11-14-2011 06:38 AM
Actuated clutch when gas off kane66 EcoModding Central 8 10-04-2008 01:32 AM
Am I hurting my clutch when I downshift without revving up? KJSatz Hypermiling / EcoDriver's Ed 17 08-14-2008 12:40 PM
