12-03-2008, 04:39 PM
#11 (permalink)
chop suey
Ever try to use logic with a gummint official?
12-03-2008, 04:58 PM
#12 (permalink)
funny you should ask, I work for a consulting company gettingpermits for new construction. so yes, everyday, and its quite interesting. once you figure out that they are all on a crusade to get whatever it is they think is important done, appease that to them, they will generally let almost anything else slide. now, getting 2 dozen of them in seperate fields and categories with seperate agendas to agree on a large developement..... well thats why companies like mine exist
12-03-2008, 05:15 PM
#13 (permalink)
chop suey
Good luck with that then. I know if I were to try licensing that thing and they saw it, I would have some splainin to do.
12-03-2008, 05:25 PM
#14 (permalink)
93 Metro Streamliner
150cc with twice the inertia, twice the rolling resistance, and nearly twice the frontal area.
fun......
12-03-2008, 05:27 PM
#15 (permalink)
drop a couple temp fenders on, one on front and one on back, full coverage just above the ground, noone will notice
12-05-2008, 03:00 AM
#16 (permalink)
Misanthropologist
The front suspension is very interesting.
However, the rear suspension looks really flimsy and cramped. I also can't see two shocks back there to corroborate the claim that the rear suspension is independent. All I see is a center mounted brake rotor and a single axle, which would mean only the front suspension is independent. The extra-wide rear footprint will make the turning profile of this thing terrible.
Just too gimmicky. Is basically just a girthy pocket bike with 12x3.5-10 wheels.
http://www.atvdiscounter.com/Motorcy...oductInfo.aspx
I'd rather convert a really light frame motorcycle to electric.
12-09-2008, 06:54 PM
#17 (permalink)
Ex-lurker
Looks like a good starting point for a very aero'd out little bike. Too bad it'd be too small to ride on streets where the SUV's will run over it without notice. And the 2 extra wheels would have to go. And you'd need an aero backpack to carry anything in. Yeah... better to scrap the whole thing
I believe the 2 extra wheels were necessary for the original V10.
12-09-2008, 11:36 PM
#18 (permalink)
Amazing copy! I bet you could get the 250cc version, take a direct side photo to the DMY and licence it here! Gimmicky as heck - might be illegal for some reason, but until the authorities catch on, might fit right in with local alternative bikes! Very clever!!
12-10-2008, 09:13 AM
#19 (permalink)
with an engine the size and weight of the dodge V10, yes, 4 wheels were needed just to hold it upright. though this isnt the only heavy motorcycle, honda's goldwing easily weighs 900lbs and there are some harleys that around around the 900-1000lbs mark, but if I recall the tomahawk was 1200lbs or more, at that point and because the seating position is how it is (very stretched with a very wide spread below the legs, no leverage to the ground) you could never ride it up on stage and hold it there unless you were a WWF wrestler.... and then the bike wouldnt look as impressive cause it'd have a giant on it
06-07-2011, 03:26 PM
#20 (permalink)
The first thing I thought was, I wonder how hard it would be to knock one of the rear wheels off? Bam, 3 wheel cycle and likely more efficient.
Look at how big its "belly" is, think there's some good storage space in there? That's gotta be good for something. Goofy or not, I bet some fun could be had with this thing.
2001 ZR2 Blazer e85/gas flex
