Old 04-30-2010, 12:01 AM   #1 (permalink)
Mifunego's Avatar
MS3 - '08 Speed3 GT
90 day: 27.15 mpg (US)
Jetta 2.0T - '06 Jetta Sedan
The Taco - '99 Tacoma Prerunner
90 day: 19.48 mpg (US)
MS5 GT - '012 5 GT
90 day: 19.71 mpg (US)
Data overload with new device
Ok, I know, there can never be such a thing... I'm a confessed Excelaholic. With the recent installation of my Accessport, I can either load a premade map or custom tune on my own, based on current datalogs, mods, and goals.
That being said, I need to sort through all kinds of juicy data that this thing monitors. I'm already making informative graphs, but I'd like to hear any other suggestions for analysis/comparison of any of the more interesting data. I'm not sure what all the MPGuinos et al. log, but this one logs about 3 times per second any or all of the following. Feel free to note your thoughts on any of these measurements:
Accel. Pedal Position (%)
Battery Voltage
Coolant Temp
Equiv. Ratio (AFR)
Inj. Pulse Width (ms)
RPM
Injector Duty Cycle (%)
Intake Temp.
Knock Retard
Calculated Load (%)
Long Term FT (%)
Mass Airflow (g/s)
Short Term FT (%)
Throttle Position (%)
Vehicle Speed (mph)
Actual AFR
Boost Air Temp
Throttle Duty Cyc.
Fan Duty (%)
Fuel Inj. Amt. (mg/cyl)
DI Fuel Pressure (PSI)
Boost/Vac (PSI)
Spark Advance
Intake Valve Advance
Wastegate Duty (%)
Any of these can also be monitored in real time on the display while logging, with min and max displayed under current.
Incidentally, this also makes some other interesting measurements and estimations, including 0-60, 60 ft., 330 ft., 1/4 mile acceleration records, and hp/tq "dyno" estimation charts. And like any good OBD II plug-in, it reads and clears error codes. Of course, it also shows estimated mpg, current and average. Why else would I buy it? A pretty neat little device, I have to say.
Old 04-30-2010, 10:16 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...which device are you using?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970˝ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 05-03-2010, 12:36 AM   #3 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
generic will not do much in a Jetta
generic
will not give up much real time info in a VW Jetta -
it will not see most of the available DTCs and it will not run basic settings
the fuel trim values are going to read Measuring Block 032 adaptives
you need to see real time STFT and LTFT values
for the Jetta
you will need VCDS also called Vag Com from Ross-Tech
or
Auto Enginuity pro line or
Enhanced for the VW and the other car you have
AE and VCDS both will run basic settings and both will have enhanced data
VCDS is better for VW
AE is better for everything else and works for the VW
edit;http://www.cobbtuning.com/products/?id=5027
never mind
it is not generic for the mazda but if it works at all on the jetta ,
it will be only generic
http://www.ross-tech.com/
for VW
this is better
http://www.autoenginuity.com/index.html
for every thing else , this is better and , AE works with VW
pricing is similar for all three IF only Mazda and VW are selected for AE
Old 05-03-2010, 01:49 PM   #4 (permalink)
Mifunego's Avatar
MS3 - '08 Speed3 GT
MS5 GT - '012 5 GT
Originally Posted by mwebb View Post
edit;CobbTuning.com - Ralliart AccessPORT
never mind
Ross-Tech: Home
for VW
this is better
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
Thanks mwebb, but I was referring specifically to the data logs from the Accessport on the Mazda (categories listed above). I'm not datalogging on the Jetta currently but should I start, I would use the VAG-COM software and dongle that I've been using on Audis and VW for the last 5 years or so. If you have any insight into using all the data that the Accessport provides (24 different logs!) I'd appreciate reading it.
How do you perform a coast down test 88CRX Aerodynamics 19 01-18-2011 09:58 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
YAG --- Yet Another Gauge DIY project JRC903 Instrumentation 2 07-19-2009 12:04 PM
Weather data, MPGs and ABA Testing. TestDrive EcoModding Central 9 04-28-2009 06:58 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
