02-18-2013, 08:45 AM
Datsun 120y coupe?
I have been thinking one of these old Datsuns might have good aero shap well at least the roof line to the back of the car. Have a look at these pics and tell me if you think it should have good attached airflow from the front of the roof to the backend?
Thanks Jamie
02-18-2013, 01:17 PM
The back looks good, but I'd check for attached flow over the hood first. If there is a big air swirl in the middle of the hood, it will benefit from some front end work. Such as a short bullet nose.
Is that the same car as the Datsun B210 that used to be sold in the States?
02-18-2013, 03:15 PM
Yeah it's the B210 here, Sunny in Japan. In fact, my desktop wallpaper is a purple B210 Excellent.
Rear end looks abnormally good for a 70's car but you'll need to redesign the front end if you hope for aerodynamics. This air dam would be a good start:
Vortexes off the sides may be a problem, though. Hard to know for sure though.
There's a guy on here that ecomodded a B210... screenname is blownb310. (In the US, the B310 generation was confusingly named "210". They did this with Bluebirds too...)
02-18-2013, 07:20 PM
02-18-2013, 07:50 PM
Wanting more for less
I've watched a couple of these on ebay, but I don't need another project that I'll never finish.
The back looks good, the front would need a little bit of work if you're serious about aero.
The great thing about Datsun/Nissan is that there's plenty of options for engine, transmission and rear end swaps. I've seen it referred to as "Giant Lego".
02-19-2013, 04:59 PM
Xist - template looks about as close as a Prius/Insight.
The car sure looks like it has potential.
02-19-2013, 06:39 PM
IMHO the roofline profile is the only thing it has going for it. There's no taper in plan; and if the body below the beltline was flipped upside down and the roof reattached it would be an improvement, e.g., lower the stagnation point.
02-19-2013, 07:04 PM
Datsun
I don't have that car in a true-length image,so It's hard to 'analyze' it,but I do have the 1976 Plymouth Arrow of which the roofline is similar and lacks very little aerodynamically.
*The Arrow returned 37 mpg HWY for Popular Science Magazine's road test.
*The X-Ray image revealed that the hoodline and nose could be lowered significantly and still contain all the original mechanicals.
*Hucho demonstrated that very little leading edge radii would allow for completely attached flow in the front and it would be a snap for the Datsun.
*With a 'cleanup' you ought to easily see low,to mid 40s mpg.
*I'd give it a thumbs up as a project car.
02-19-2013, 11:01 PM
#9 (permalink)
Rake it. Nose down it will have better compliance to the Template.
How much are you willing to extend the length front or rear? I mean, if you had one. A bullet nose (carved back or added on), belly pan, rear diffuser/boattail, and work on the wheel wells would return dividends.
There's a pretty heavy shadow under the rain gutter on the A-pillar. Here's what the Porsche 911 folk do:
http://www.gerrelt.nl/section-aerody...windnoise.html
They claim 5 km/h more top speed. I don't know what that translates to in Cd, but it will help with wind noise at the very least.
02-20-2013, 02:07 AM
#10 (permalink)
I guess that the previous model was called the 1200 and supposedly had a Cd of 0.42
Tech Wiki - Aerodynamics : Datsun 1200 Club
