Old 11-02-2012, 07:14 PM   #1 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
DIY Freeze Plug Engine Block Heater Install, 1989 Corolla
I hunted around the web before I did this, but never found a tutorial showing a freeze-plug engine block heater installation on any car. (EDIT: I should say I didn't find any that I thought were more than a little bit helpful and/or pertinent.)
... probably because it isn't a common thing to do. If you live in the great cold north, your cars come new with OEM heaters, and if you don't, you presumably don't need one.
I added a heater and did it the OEM way, and wrote a tutorial.
You can read all about it here:
DIY How to Install a Block Heater, 1989 Corolla | Christofoo Review
Of course the details depend a great deal on make/model.
Let me know if you find it helpful.
Cheers,
Chris
Old 11-02-2012, 11:44 PM   #2 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
Just a tip about the copper exhaust gasket, watch the bolts carefully for the next 2-4 weeks. My camry got a new exhaust manifold back and that ended up being a problem area. It came loose enough to leak twice in 40k miles. My car has 3 bolts in that area, looks like yours is only 2.
Nice tut, I might have to do this someday. What kind of costs did you run into for this?
Old 11-03-2012, 05:26 PM   #3 (permalink)
christofoo's Avatar
Thanks.
Heater: $40 IIRC ($18 for Kats brand online)
Manifold gasket: $19
Exhaust pipe gasket: $3
So it could be as little as $21 (+tax) if you get Kats and take a chance and skip the manifold gasket. My grand total was $62. I had all the tools handy.
Assuming you don't have the warm-air-intake like my 4A-F (and everything else is the same) I would consider leaving the manifold in place for the operation. (But don't be too surprised if it doesn't pan out.)
