01-30-2008, 10:26 PM
#11 (permalink)
Giant Moving Eco-Wall
Yea... yea... that was me. Except We were going about 20 mph, backwards in neutral downhill with 3 people in a stock Club Cart, gas. Our driver which is my step cousin slammed on the brakes and we were literally straight up. There were no wheels on the ground when we did it, and I think we killed the suspension. We would have died if it did flip. Those bars that hold up the roof aren't designed to hold a golf cart...
01-30-2008, 11:28 PM
#12 (permalink)
I"m not lurking!
Originally Posted by MetroMPG
If you're a true hypermiler, you'll find a hill you can do this on, so you can roll backwards with the engine off while doing these start/stop brake applications
You got me on that one
Roll on,
Stew
01-31-2008, 12:55 AM
#13 (permalink)
Awesomeness personified
Originally Posted by s2man
I've even got special tools for adjusting drum brakes without taking off the wheel and drum, they are in with my special points and timing tools  .
Well, you weren't showing your age too bad until you mentioned that you used to own a car that used points
Like most young fellas, the only stuff I know about points is from the article I read in Grassroots Motorsports about restoring MGBs (or maybe it was old Volvos)
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
02-03-2008, 12:30 PM
#14 (permalink)
Yaris What????
Yari - '07 Yaris Liftback
I have used the star adjuster tool before but I found it easier to just take the wheel of and adjust manually. That was also when I had a lift available. I guess if you're working on an Old T-Bird that was run hard, I suppose a star adjuster wouldn't work aswell as removing the wheels.
Yaris Liftback + 3 Adults + Toddler + Luggage/Crap = 40mpg@80mph
It just came to me about blogging lol. Its like an orgasm a few good shots and the rest is dribbles lol!
02-03-2008, 12:33 PM
#15 (permalink)
Yaris What????
S2man when you started talking about throwing the tarp over a car I thought you were doing that to try and keep the drums from getting to moist......then I realized you did that to try and keep warm LOL. Never thought of that, but I love my paint too much to try it.
02-05-2008, 12:12 AM
#16 (permalink)
The absolute first thing to do when the parking brake no longer works as it should is check the rear brake pads, not saying they are worn but this is one of the signs the car gives off as it tells you they could need replacing.
Once they've been checked out, if they need replacing then as likely this fixes the problem, if not then adjusting the cable itself should do it, but check the pads for wear first, replace if needed, then adjust the cable if it's still off, in that order.
Please.
02-06-2008, 10:21 PM
#17 (permalink)
Yaris What????
I have checked the pads and they are fine. The pull brake does work, but it is not as tight as it should be. What is the actual process of tightening. I believe the nut is located inside the consul. How do I go about tightening?
02-06-2008, 10:31 PM
#18 (permalink)
Nomadic Chicken
Q: if you can't tighten the end of the cable that is under the console, can you tighten the cable at the other end?
02-07-2008, 12:40 AM
#19 (permalink)
40 MPH - Achieved!
Since it is an '07, can you take it to the dealer for a warranty or courtesy 'adjustment'?
02-12-2008, 10:22 PM
#20 (permalink)
Ecomod noob
ZJ - '95 Grand Cherokee Laredo Upcountry 90 day: 20.57 mpg (US) Neon - '03 Neon SE 90 day: 36.28 mpg (US) S'Crew - '02 F150 Supercrew XLT 90 day: 16.4 mpg (US) EX - '94 Explorer 90 day: 19.58 mpg (US) Ranger - '90 Ranger Last 3: 28.02 mpg (US)
Other question is, why would it need adjusting so soon? I recently have changed rear brakes on 2 of my vehicles where the parking brake wouldn't adjust anymore. Since one was a rear disk vehicle, I pulled the rear rotor and found NO PADS on the shoes... The other was a rear drum and needed new shoes, as well as new cables too.
When it comes to Heroes, RENEGADES are mine!
