Old 01-25-2010, 08:46 AM   #1 (permalink)
Does dirty fuel filter cause bad economy?
Hello.
I have read on various forums that people have experienced better fuel economy after changing their fuel filters.
I'm wondering, how can a dirty fuel filter cause the vehicle to use more fuel?
wouldn't it use less?
Thanks.
Old 01-25-2010, 08:48 AM   #2 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
It can cause you to have worse, but most of the time it doesn't. (at least in my case)
Old 01-25-2010, 09:04 AM   #3 (permalink)
Thanks,
I'm wondering though, what is the technical explanation behind it causing bad fuel economy.
Old 01-25-2010, 09:39 AM   #4 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If the filter is clogged, it won't run. If it's restricted, it simply makes the pump work harder.
Old 01-25-2010, 04:19 PM   #5 (permalink)
Originally Posted by Z2TT View Post
Hello.
Thanks.
Z2TT,
A dirty fuel filter makes no difference to economy but it usually restricts the upper rev limit simply due to lack of flow.
Totally blocked the filter simply stops the engine since fuel can't get through.
Pete.
Old 01-25-2010, 04:35 PM   #6 (permalink)
Mater - '98 3500 Dually
Wilber - '99 Corolla LX
Minyatta - '93 Miata MX-5
By trying to keep the engine running, the natural impulse is to add more throttle. So to make up for the restriction we try to add more fuel by pumping the accel pedal. So for instance instead of having the engine cruise at let's say 1500 RPM we overcompensate & the result is a fluctuation in overall engine speed 1250 to 1750 to 1400 to 1600, just trying to keep a steady 1500.
Dave
Old 01-25-2010, 05:18 PM   #7 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
If only K&N made fuel filters- think of the power and economy!!!
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
Christ (01-26-2010), vtec-e (02-01-2010)
Old 01-26-2010, 08:18 AM   #8 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
I thought the dirty air filter thing was from back when cars were carbureted. Doesn't a restriction in airflow act as a choke, making the engine run rich?
Old 01-26-2010, 08:48 AM   #9 (permalink)
Frank Lee, what is your reasoning behind the K&N fuel filter. I run a K&N air for my truck, I noticed a difference right away. Is it an ultra low restriction gas filter?
Dave
Old 01-26-2010, 09:10 AM   #10 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...DANGER, Will Robinson, DANGER!
...if you use both a K&N air filter and a K&N gas filter, you'll save so much gasoline that it will backup and overflow the gas tank capacity, causing hydrocarbon air pollution and a fire danger (wink,wink)!!!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
CoastRider (01-26-2010)
List of common mechanical problems that hurt fuel economy Andyman General Efficiency Discussion 8 12-20-2011 06:29 AM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 5 10-09-2009 11:09 AM
Drive Like a Trucker for Great Fuel Economy SVOboy EcoModder Blog Discussion 12 08-18-2009 09:20 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
