Old 03-23-2010, 10:13 AM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 28.73 mpg (US)
Help from someone that know about cars?
Ok this is a stupid question because I don't know anything about cars really but...
The sensor that is hooked to my intake box that the mechanic said "has a spring and a plunder mechanism that tells the car when its in park" or something like that is broken, I forgot what the abreviation of the sensor was but ANYWAYS if you know what it is...
... Is there any better MPG version of this sensor?
Might be a question that make NOOOOO sence but if im going to replace it I might as well get the better MPG version if it exists...
I dont know anything about sensors or whatever
Old 03-23-2010, 08:49 PM   #2 (permalink)
Send a message via AIM to pumafeet10
might be talking about the TPS= throttle position sensor
Old 03-23-2010, 09:02 PM   #3 (permalink)
Hyperlurker
daring4's Avatar
D-max - '04 Chevy Silverado Ls
Notch - '65 Volkswagen 1500 S
MTCHBX - '05 Scion XB
90 day: 40.41 mpg (US)
Do you have a pic of the sensor? The neutral safety switch on auto trannies is what tells the computer the gear you are in. Sounds to me like the air filter sensor to tell you it is plugged up. It has a spring and plunger to measure vacuum on the air filter side. If thats whats it is you can just plug it and not worry anymore...
Darin
Old 03-23-2010, 10:27 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
You're not going to go to the auto parts store and buy a high fuel economy version of any sensor. Generally, the thing to do is replace broken sensors, then tell the computer lies by adding resistors, toggle switches, etc. as appropriate to make the computer think it's time to inject less fuel. But if you don't know anything about a certain sensor and how your ECU responds to it, I don't recommend messing with it.
Article: Want cars to eat less? Put 'em on a diet MetroMPG General Efficiency Discussion 34 07-14-2013 01:38 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Cars compared in wind tunnel Bearleener Aerodynamics 30 08-26-2011 05:38 PM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
